Headlights shutting off randomly?
Old Sep 17, 2006 | 06:26 PM
Fordtoughranger's Avatar
Fordtoughranger
Truck:
1977
F150 Ranger
429ci
Problem seems to be with the headlights heating up and shutting off light a circuit breaker would do. Once the go off they come back on after a few minutes. Being unfamiliar with wiring in this year of truck I am wondering if there is some kind of thermal relay that shuts the lights off if they are burning too hot or pulling to much amperage?
Any ideas advice would be helpful!
Thanks
Fordtoughranger
Old Sep 18, 2006 | 10:32 AM
subford's Avatar
subford
You need to replace the Headlight Switch, the circuit breaker is inside it.
Old Sep 18, 2006 | 09:03 PM
Fordtoughranger
Sorry guys I should have mentioned that the headlight switch has already been replaced. So any other possibilities or reccommended brand of switch?
Old Sep 19, 2006 | 12:31 AM
Franklin2's Avatar
Franklin2
Take the switch out again, and look at the electrical plug. If it looks melted and like it has been hot, it could be causing a bad connection, which is overheating the switch and making it trip out.
Also check out the dimmer switch in the floor. They lead a rough life down there, and sometimes they get corroded and the wiring does not make a good connection.
Bohman731
15
Jul 14, 2014 11:49 AM
Ruckess
Sep 17, 2009 04:39 PM
Fordsflylow
Dec 4, 2008 01:40 PM
ajhawkins
1997 - 2003 F150
Mar 29, 2007 03:36 PM
cricketlacy
Sep 28, 2005 09:51 PM
