My driverside door's electrical is all screwed up. I will have my ignition in the run position and my whole door is electricly dead: locks, windows, mirror adjustment, mirror heater, and the outside mirror marker light. However, if the key is off, or in "acc" position, all but my window buttons will not work. When I have my ignition in the "acc" position and I push the driveside window button to put the window down all I get is a "buzzing" sound. Is there someone that could point me in the right direction in order to fix the issue. I have checked all my fuses and they are all good. I am clueless.
