How crazy is this thought
Old Sep 23, 2012 | 10:34 PM
Adventure Rider's Avatar
Adventure Rider
Changing my oil at 3000 miles - Also rotate tires
Check/Drain water seperator
Replace Fuel filters
The thought behind this is to clear out all the break in stuff
Old Sep 23, 2012 | 10:56 PM
XPD77's Avatar
XPD77
I was wondering the same thing. Someone had suggested I do it.
Old Sep 24, 2012 | 12:18 AM
mrjc's Avatar
mrjc
The oil, a resounding YES. The fuel filters? Air filter is probably dirtier than your fuel filters.Your tank and lines are probably their cleanest until you run a few tanks, why change them? I and others drain the DFCM more often. I do that every 2 months, others do it more often and of course water in the fuel is not dependent on mileage. Tires wouldn't hurt. How are you ensuring your DPF is clean? Tranny filter? Power steering fluid? Coolant probably has stuff in from manufacturing and break in but messing with it could induce problems. I did my oil and filter at 3,000 and the other stuff can wait until they are due. I also washed my engine. It was pretty dirty especially after I got the oil bolt out, the oil stream way overshot the container I had waiting underneath, not to mention after loosening the filter the oil just kept coming out and getting everywhere. Took me a long time to clean the mess up. Will position the catch basin 3 feet away next time.
Old Sep 24, 2012 | 12:30 AM
Adventure Rider
I was thinking of the drive train fluids also (frnt/rear diff, transfer case) tranny thought those would be more robust
As for the coolant same reasoning you mentioned.
Thanks for the heads up on the oil release - will be doing this on my friends lift and would want to minmize my clean up
Didnt think of the air filter
Old Sep 24, 2012 | 12:48 AM
cford716's Avatar
cford716
Water separator is recommended every month. I believe the coolant is rated to 100,000 miles but don't quote me on that. This coolant is an expensive change if you are going to do it.
Oil I waited to 5000. I am now running Rotella t6 and wait until it tells me to change it. I am at 33,000 miles.
You can do whatever makes you feel comfortable, but I think most would think its overkill.
33,000 miles on the truck not the oil.
Old Sep 24, 2012 | 01:10 AM
Adventure Rider
Thanks
this is my first diesel and want to make sure i am doing all the right things
Maintanence is low hanging fruit for prevention plus it will give me a sense of how to work on the truck and i will have everything done before the weather hits
Right now i am leaning to do the following
- oil and filter
- DFCM drain
- air filter (check)
- rotate tires - this will allow me to check breaks, fittings and lube anythig that needs to be lubed
- probably fill the DEF tank
Will waiting for any additonal posts and comments
Old Sep 24, 2012 | 03:32 AM
cford716's Avatar
cford716
One thing on filling the DEF. I think many like myself wait until you get to half tank then wait a little longer and put in a 2.5 gal. jug. That way avoids having a partial jug laying around. Also be aware you need to trip the sensor to reset that level, it is not a direct read for the tank.
It's a great truck.
Old Sep 24, 2012 | 03:45 AM
Adventure Rider
Thanks - still learning. Sounds good will wait until advised by the truck
+1 on great truck!
Old Sep 24, 2012 | 07:22 AM
rtazz17's Avatar
rtazz17
It's a great truck.
When I filled mine it said below half,I added 2.5 gallons and did not have to reset the sensor to get it to read correctly.I turned the key and it was correct.Maybe im misunderstanding what your saying but I didnt have to trip anything to reset...
Old Sep 24, 2012 | 08:36 AM
Rod Bensken's Avatar
Rod Bensken
Not crazy, I'm changing mine at 4K. If nothing else it's piece of mind.
Old Sep 24, 2012 | 09:56 AM
rob17's Avatar
rob17
Same here.
Rob
L-ight
24
Oct 19, 2017 09:55 AM
BlackBeest
6.7L Power Stroke Diesel
Oct 9, 2013 08:50 AM
greenheads
Oct 17, 2011 10:02 PM
Loopy
Aug 16, 2010 12:45 PM
FORD352V8
Oil & Lubrication
27
Sep 24, 2004 10:18 AM
