Digital Volt Meter. In another thread I suggested checking in the North Carolina chapter to see if there might be a FTE member close to you. Did you come up with anything on that route?
when i took the oil cap off there was no oil in it idk if there its suppose to be while its off but i turned the key on and no oil came up and bumped it over and nothing happened..never seen the iol....it has oil in it too
S!@T things may have gone Bad to worse I hope not though I wont jinks it
Theres your problem maybe
there is a drain in the bottom the oil filter housing you should hold down while someone cranks
its Black hang on I will post a pic
of that and the LPO regulator it might need clean a few got stuck open and simole cleaning got it working again
ok i pushed it down and tried to crank it and no oil came through..so whats that mean the oil pump is bad
This isnt GOOD at ALL
Originally Posted by alexisvfd
is there anyway to test oil pump another way before i spend my life savings on it
Look at the Pic I posted of the LPO Regulator Pull it and Clean it
if that dont help Time to pull the front Cover and inspect the LPO Gears
Also Drain the Oil and Filter it see what you Find
IF its got a Bad LIFTER the bearing normaly drop out and eat the LPOP and at this Point its time for a New Engine shure you can fix the LPOP but you also have to replace the Lifter and Camshaft
when a Lifter Fails the entire Engine Must be disassembled as the Cam Shaft and Lifters are the Last thing to come out and first to go in when assembly time
