NP435 4x4
Old Sep 23, 2012 | 08:46 AM
lafermedavid's Avatar
lafermedavid
NP435 4x4
NP435 out of a 75 HB,pulled head off looks real clean ,notice lower main gear, two chiped teeth.JBG carries that gear,any one have an Idea what it would cost to have that replaced and syncros new installed.rough idea. thankyou my tranny is out of my frame
Old Sep 23, 2012 | 09:07 AM
lostinfords's Avatar
lostinfords
price it out at a trans rebuilder and if it is too much you can buy my trans from my 74 HB ..in NJ...seroiusly I don't know what it would cost, but that is what I would do if I had that problem, price to get it redone and if too much look for a good used one..good luck
Old Sep 23, 2012 | 08:02 PM
lafermedavid
NP435
Thanks alot lostinfords I will and post a reply on average cost .
Old Sep 23, 2012 | 08:15 PM
montana_highboy's Avatar
montana_highboy
lafermedavid, have you considered rebuilding the NP435 yourself, if you're even the slightest bit mechanically inclined it's an insanely easy transmission to rebuild, detailed instructions come with the rebuild kit.
The New Process 435 Transmission - Novak Conversions
Old Sep 23, 2012 | 08:23 PM
lafermedavid
NP435
Hey Montana,I took top off,and thats sort of what I thought,but just never tore into tranny,looked up gear on JBG 90$ gear 15$ syncronizers,your post is sort of what I wanted to hear.So I will attempt,Thanks Montana
Old Sep 23, 2012 | 08:32 PM
montana_highboy
It goes without saying but if you run into any snags along the way there are guys here who are more than willing to help walk you through it.
But i think you'll find it to be a pretty painless endeavor.
Old Sep 23, 2012 | 08:43 PM
lafermedavid
Novak
Thanks again Montana, there is some great info there
Old Sep 24, 2012 | 07:16 AM
1972RedNeck's Avatar
1972RedNeck
Post a picture of your gear. If it's not to bad a little filing could make it work as good as new.
Old Sep 24, 2012 | 11:58 AM
Ole Blue (Pete)'s Avatar
Ole Blue (Pete)
Anyone ever retrofit a newer transmission with overdrive? Im too cheap to pay for gas.
Old Sep 24, 2012 | 06:39 PM
lafermedavid
toothless
hey 1972 Redneck its a chunck of tooth gone,Ill work on getting a pic though.
Old Sep 24, 2012 | 07:31 PM
1972RedNeck
You can bolt an NV4500 in using an adapter plate from advance adapters. That option costs about $3000. The ranger overdrive unit by advance adapters looks like a good option for $1500 if you have 450 ft. lbs. of torque or less. You can get 15 MPG put of a high boy with a built 390, 4.10's and overdrive driving 70 mph.
Natcox012
Jan 25, 2015 10:23 AM
Dvandy21
May 12, 2014 05:08 PM
Justin2233
Jun 30, 2010 02:57 PM
Kwattro
Feb 21, 2006 12:24 PM
JTHill24
Aerostar
Aug 15, 2002 06:46 AM
