PROJECT HELP
Old Sep 22, 2012 | 09:11 PM
rowbaird's Avatar
rowbaird
Exclamation PROJECT HELP
so what i am working on is a 1993 f250 that was the 7.3idi turbo diesel and i had a 96 di powerstroke motor in the garage and decided that i wanted to put the 96 motor in my 93 pickup so all has went good so far engine fits in bolts up and is looking good. Well the wiring has been a bit of a pain i had a 96 parts truck that i had purchased a few months back for this very reason jobs like this so right now i have rewired under the hood and in the cab and i am getting no power into the cab nothing at all i am stumped got any ideas??
Old Sep 22, 2012 | 09:27 PM
Red97350's Avatar
Red97350
Just throwing out guesses here, but something to do with the plug at the firewall? Not sure if you just unplugged the under hood harness from the idi and plugged the powerstroke harness in. Maybe they are set up differently? Hope this helps, just throwing out guesses.
Red
Old Sep 22, 2012 | 09:50 PM
fordpride's Avatar
fordpride
Did swap ALL the wireing harness and fuse boxes from the 96 to the 93 ?
Old Sep 23, 2012 | 01:48 PM
95350PS's Avatar
95350PS
Is the battery hooked up lol im just kidding i hate wiring it gives me headaches lol good luck though
Old Sep 24, 2012 | 07:10 AM
rowbaird's Avatar
rowbaird
yes i did a complete swap i took all of the 93 wiring out and put the 96 in but i opened the fuze pannel and no fuzes or relays were present so i repaced them and everything is lighting up but my key isnt starting the truck si im putting in a push start
Old Sep 24, 2012 | 07:31 AM
fordpride's Avatar
fordpride
Can you crank it by jumping the solenoid on the pass fender
Old Sep 24, 2012 | 08:28 AM
rowbaird's Avatar
rowbaird
yes it does
Old Sep 24, 2012 | 09:19 AM
rodneywar's Avatar
rodneywar
is it manual or auto
Old Sep 24, 2012 | 12:53 PM
rowbaird's Avatar
rowbaird
5spd manual
Old Sep 24, 2012 | 02:58 PM
fordpride's Avatar
fordpride
Did you use the steering Column from the psd ?
Old Sep 24, 2012 | 03:03 PM
rowbaird's Avatar
rowbaird
yea i did i could be that but a push start button wouldnt be that hard to put in because the key starts up all the pumps and every thing when i put it over in the run position
Old Sep 24, 2012 | 03:06 PM
ReBilld's Avatar
ReBilld
Did you check the clutch safety switch?
Old Sep 24, 2012 | 03:55 PM
rowbaird's Avatar
rowbaird
no actually i didnt where is it located
Old Sep 24, 2012 | 04:00 PM
thebig350's Avatar
thebig350
Above and behind the go fast pedal.
Old Sep 24, 2012 | 07:00 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Last time I checked, the bulkhead connector on the firewall for the interior electronics is pinned differently between '93 and '96.. Are you using the original '93 interior harness or the '96 interior harness?
429Pinto
15
Mar 11, 2019 10:40 PM
82F100SWB
May 6, 2016 01:26 AM
Michael ramero
Engine Swaps
Jan 14, 2016 07:03 PM
rnfordahillshick
16
Jan 2, 2015 04:36 PM
jerry sr
Nov 28, 2014 04:57 PM
