I'm looking for pic of the cruise control set up on my truck. The truck has cruise control on the turn signal switch and a box where the speedometer cable go but everything else is missing. Need help
I'm looking for pic of the cruise control set up on my truck. The truck has the cruise control switch located on the turn signal handle and a box where the speedometer cable goes, but everything else is missing.
Your truck has either Ford dealer installed (A/T only) or aftermarket Speed Control, it's not factory installed.
D4AZ-9C888-A = Dealer installed switch located on turn signal handle, marked: RESUME-ON-OFF-SET SPEED
Dealer installed shown here: 1973/79 Ford Light Truck Parts Catalog / Illustration Section 97.1 - Page 1.
FTE member mikeo0o0o0 has this catalog on a CD, will scan/post pics.
Factory installed Speed Control has the switches located in the horn pad.
Bill you never cease to amaze me. Your wealth of knowledge, photographic healthy memory and hands on experience leave you number 1. But are ya physic also? Wouldn't surprise me any.
How the heck did you know that unit was aftermarket from his post? Inquiring minds need to know.
Seeing as it's not an OEM set up, your best bet is to probably look for another complete unit......with the manuals. There were several different aftermarket cruise controls offered over the years and knowing which one you have is difficult at best. Most (?) were manufactured by Perfect Circle Corp. but sold under various brand names.
As to your unit. You should have the controls (on the T/S stalk) the control box (usually under the dash or hood) speed sensor, vacuum servo and the various vacuum lines and wires that tie it all together.
Here are two illustrations from the Ford parts catalog. The first is the dealer installed cruise, the second factory installed.
Click on the links to view.
Servo assy, speed control
use w/ dealer installed speed control
75-78 F100-350 2WD w/ automatic trans
D4AZ-9C735-C
I located 11 at various dealers and obsolete suppliers, let me know if you want the names.
The catalog only shows for 2WD but I don't see why it couldn't be used on a highboy.
They'll have to get it from one of the dealers that has it, it's been obsolete for a while.
Here are a few of the ones that I located.
Green Sales, Cincinnati, OH has 3 (800) 543-4959
Parts International, Farmers Branch, TX has 1 (972) 241-8730
Kinsel Lincoln-Mercury, Beaumont, TX has 1 (800) 816-2894
