Hard Start After Sitting
Old Sep 21, 2012 | 10:05 PM
ChristopherN's Avatar
ChristopherN
Hey all, been a while...
Anyways,
My truck has been hard to start after sitting, it doesn't matter matter if it's cold or warm outside. It takes a good 3 seconds before it turns over and does it's usual high rev and then drop down to normal idle thing.
I can do a half crank and then a full crank and get an almost instantaneous start. Because of that, I feel it's not related to the fuel pressure. Also because I can prime it all I want and it still take 3 seconds to start. Sometimes the idle surges and almost always after say driving to a store, coming back, starting it and then putting into gear I get a rough idle.
I've replaced the fuel filter last week and dumped Sea Foam in the gas. My mpg increased slightly, but that's it.
Googling suggests a possible bad pickup coil or MAP sensor? But the truck runs like a top otherwise.
Last tune up was about 12,000 miles ago... But even after first installing the new rotor, cap, plugs, and wires it did this exact issue.
Old Sep 22, 2012 | 11:18 PM
Thumper19's Avatar
Thumper19
I have the exact same issues with my 302. I have replaced everything sensor related. And after $200 later it still does it. I did a fuel pressure test and pressure is fine. I am now putting in new injectors in bhopes it does something. Other than that I will be lost. I have replaced everything with oem motorcraft and still no fix.
Old Sep 23, 2012 | 07:37 AM
Freightrain's Avatar
Freightrain
When cold, mine fires right off. After warm, it takes a few cranks to get it to fire most times. It's had a good tune up, everything checked and rechecked and works fine, truck runs fine. Still hard start when warm(most times).
89 302/aod
Old Sep 23, 2012 | 11:27 AM
Thumper19's Avatar
Thumper19
Same scenario with me. In winter it starts like its nothing.
Old Sep 23, 2012 | 12:31 PM
macawmatt's Avatar
macawmatt
Had the same issue this weekend, but its also the first time I used the rear tank since I bought the truck two weeks ago. Thought it might be an issue with the lines draining back on that tank or something.
Old Sep 23, 2012 | 02:35 PM
Thumper19's Avatar
Thumper19
Fuel pressure is not an issue in this situation
Old Sep 24, 2012 | 08:33 AM
ChristopherN
Thumper, did you replace the pickup coil in the distributor?
Old Sep 24, 2012 | 08:39 AM
Thumper19's Avatar
Thumper19
I don't believe I have. That's the little deal inside the distributor right? Aka the PIP.
Old Sep 24, 2012 | 08:48 AM
ChristopherN
I'm not sure but, that's the last thing I'm thinking of. Seems to come up alot when I google it. However, when a pickup coil goes bad it causes the car to not run. Maybe we're catching it early?
Old Sep 24, 2012 | 10:24 AM
Thumper19's Avatar
Thumper19
Yeah I know when a pickup module is going out it will cause it to not run. I don't think that's the case here because I am getting spark.
Old Sep 24, 2012 | 11:07 AM
ChristopherN
TFI module maybe?
Old Sep 24, 2012 | 11:30 AM
Thumper19's Avatar
Thumper19
Has a new one
Banjo250
1997 - 2003 F150
18
Jul 2, 2019 04:29 PM
sam hain
1997 - 2003 F150
Aug 7, 2017 02:37 PM
dpoc
18
Sep 25, 2011 08:39 PM
1984F15016
Aug 3, 2009 01:17 PM
f1501988
Oct 11, 2003 09:37 PM
