ifs
Old Sep 21, 2012 | 08:27 PM
MSCritter's Avatar
MSCritter
ifs
goodday everyone can someone tell me how much power a dana 44 ifs handle on the street ex. 386 hp. with a little abuse once and awhile. Is 100 hp nos on top asking way to much thanks and have a good weekend
Old Sep 21, 2012 | 08:47 PM
Gary Lewis's Avatar
Gary Lewis
Sorry - using 4wd drive on the street? It won't last with 100 HP if you do it often and turn any corners.
Old Sep 21, 2012 | 08:58 PM
MSCritter's Avatar
MSCritter
straight line bursts 60 foot green light go like hell kinda thing
Old Sep 21, 2012 | 09:02 PM
Gary Lewis's Avatar
Gary Lewis
OK, given that you won't have the bind that can kill it, quickly. But, you either have to drive around with the hubs locked, which will create the bind on corners, or stop and lock them in. In any event it wasn't designed for that. Good luck.
Old Sep 22, 2012 | 06:02 AM
garthneddy's Avatar
garthneddy
Having the hubs locked in on the street will NOT cause the front axle to bind unless you have a spool in the front axle. Many vehicles come from the factory with the front axleshafts permanently engaged at the wheel.
Old Sep 22, 2012 | 07:14 AM
CountryBumkin's Avatar
CountryBumkin
I have 600HP on my build. I don't run in 4x4 on the street, but IMO if you did you would lose traction long before you broke anything. I've a done a burn out or two on the street and basically the tires will get all greasy (melted) and the truck will quickly be facing the wrong direction (if your spinning the front and rear tires you can't steer).
Old Sep 22, 2012 | 08:42 PM
batchman's Avatar
batchman
Not enough info from the OP to know.
For instance, my 84 Bronco (purchased new) has an IFS D44 and an 8.8 rear. The ratios are slightly different owing to what's available in the different housings. It's not much but dry pavement can certainly build up some bind, even in a straight line, and this may be why the factory docs all warn not to do that.
Best,
- Jeff
Old Sep 22, 2012 | 09:32 PM
MSCritter's Avatar
MSCritter
ill be running 3.50 gears, lock right rear and ltd slip front when i find one ill be 2 wheelin it most of the time but once and awhile, well you know those unsuspecting guys and oops whered they go lol
Old Sep 23, 2012 | 06:01 AM
garthneddy's Avatar
garthneddy
It doesnt have anything to do with gear ratios. The transfer case only locks the front and rear axles together when it is engaged in 4hi or 4lo, therefore in 2wd the front differential can spin at a different speed then the rear differential. Lock your hubs in on the street or take a ride in some Chrysler products that have unit bearings. I can guarantee you will feel no binding in the front axle
Old Sep 23, 2012 | 08:18 AM
bashby's Avatar
bashby
True. My dads trucks NEVER get the hubs unlocked, even on long trips. (not saying its a good idea) I know when I forget to unlock mine I can feel a slight vibration at highway speeds, but no binding with the TC in 2wd.
Old Sep 24, 2012 | 09:11 PM
zax722's Avatar
zax722
Leaving the hubs locked has never been a fan of mine because it can cause unnecessary wear on bearings that would be turning at all times. I also believe that it lowers fuel mileage. just IMO
Old Sep 25, 2012 | 04:17 AM
CountryBumkin
It definately lowers fuel mileage. With the hubs locked your turning the ring/pinion gear. This extra drag and friction is overcome with more fuel.
BTW - you need to run with the hubs locked in from time to time (if you infrequently go off road) so you do turn the gears. This is how the bearings get oiled.
joeyd61
Oct 11, 2013 03:46 PM
Scramblerj
Ford Truck Parts for Sale
May 15, 2013 10:55 AM
TheWedge1
Dec 4, 2010 11:14 PM
high-tide
Oct 20, 2010 04:18 AM
bewford
Feb 14, 2010 06:54 PM
