obd 1 codes need help
181 should be lean, not rich, and disregard the right/left stuff, your computer only sees it as one.
Check your connections and fuel pressure.
Check for vacuum leaks.
Do you have dual tanks?
Do you have an exhaust leak?
For the 332, check the Exhaust Valve Position Sensor connector and check the voltages. Haynes has a procedure for this.
Also, check the vacuum actuator line (I think its green) that plugs into the top, IIRC it holds a vac when off, if not take it off at the other end and see if it holds vacuum pressure.
-Mike
EDIT: If I Recall Correctly
-Mike
What do you mean when you say breather? Is it open to the air? If so, that's your lean code. If not, Check fuel pressure, and if that's good, clear the code and give it some driving to make sure it wasn't a one time thing. If the EGR is open to free air, you will need to block it off or (ideally) reconnect it. And true duals would have 2 exhaust pipes, so saying the O2 is on the exhaust pipe is not particularly descriptive, however clarification is unnecessary at this point.
-Mike
-Mike
1996cyl
25
03-24-2011 01:05 PM
truckdriver_mn1984
07-19-2009 05:33 PM
El Chorizo
02-19-2009 11:13 AM
