AIH "Soft Code"
Old Sep 20, 2012 | 03:13 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
AIH "Soft Code"
I need information on the code the AIH throws. My smog check up is soon and I hear that can fail you sometimes.
Old Sep 20, 2012 | 03:17 PM
timmyboy76's Avatar
timmyboy76
https://www.ford-trucks.com/forums/4...mod-wires.html
Old Sep 20, 2012 | 06:15 PM
BigAlsPSD's Avatar
BigAlsPSD
Nevermind... Need to pay attention to what you are asking...Sorry Trey.
Old Sep 20, 2012 | 06:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If the blue wire is still connected do I need a resistor? The first thread is kind of confusing.
Old Sep 20, 2012 | 06:21 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Trey,
Do the smog testing stations in your area have the ability to scan these trucks? Here in Arizona they just do an opacity test (snap test in Maricopa County or roller test in Pima County). Unless they can scan your truck, they'll never know about the AIH soft code...
Old Sep 20, 2012 | 06:23 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by Shake-N-Bake
Trey,
Yep they plug in. But I dont know to what extent. I dont know if they just check for codes, or if they actually try to pull codes. They dont to any computer tests though, just a code check.
Old Sep 20, 2012 | 06:40 PM
Shake-N-Bake
Bummer.
It might be easier just to put the AIH back in temporarily and then go through smog...
Old Sep 20, 2012 | 06:45 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Good thing I kept it, but the wires didnt come off too cleanly. I could probably make it work though.
Old Sep 20, 2012 | 06:58 PM
BigAlsPSD's Avatar
BigAlsPSD
You need the blue wire to be able to run CCT tests supposedly, although I cannot confirm.
The resistor is to give a draw to the power output from the relay to signal a loaded situation at KO tests. During a test, if they are actually pulling codes, then when activated the relay needs a load. Just rig up a temporary, permanent, wire going from the output of the relay to ground with 2 sets 470 ohm resistors twisted together, wrapped with electrical tape and wire loom, and connect the other end to a ground.
Old Sep 20, 2012 | 07:00 PM
brian42's Avatar
brian42
Veteran: Navy
Mine passes CA smog test with my AIH deleted and no "mod" for the soft code.
Old Sep 20, 2012 | 07:06 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thanks for the resistor info.
Thats what I was pretty sure of. They didnt scrutinize too much last time when I didnt have a CEL.
Old Sep 20, 2012 | 07:29 PM
Stewart_H's Avatar
Stewart_H
AIH delete with no resistor mod will not fail you.
I have the AIH deleted on the Ex and the 250 and have never had a problem when getting them smogged.
Stewart
Old Sep 21, 2012 | 06:21 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Perfect. Thanks!
That's the only thing I was worried about, other wise smog is pretty easy. Even here in California.
Old Sep 21, 2012 | 09:50 AM
timmyboy76's Avatar
timmyboy76
passed my test, in July....AIH deleted, wvo system, FRx, HPx....and the best thing, i JUST found out the other day, when messing with my el-cheapo scanner, that my OBD plug had no power to it. Pulled the fuse panel, only to see the fuse was missing. WHO KNOWS when that damn thing was removed...lol
Old Sep 21, 2012 | 02:06 PM
1fixitman's Avatar
1fixitman
What is the fuse number to the supply for the OBD II? Thanks.
