Before painting would be a great time to add little things to the frame like retainer mounts for fuel lines, wiring, exhaust hangers, etc
Personally yellow is my least favorite color in existence, doing the frame yellow would be overkill.
I definitely will be adding those mentioned things. And actually what I'm thinking is to mount a plate that runs the length of the frame between the wheels on the drive side. And on that plate I will be able to secure all the brake and fuel lines as well as the harness. Then from there I will have spacers and another plate to protect said items from being snagged.
But I'm gonna start rattle canning soon just because I know the rear suspension will be much easier. And after that I'll start mounting the cab. At which point it may be too tall to fit inside the garage and I would like to protect all that steel from the elements.
And yea even though I love the color yellow I don't think it would work out. So for now it will probably just be black.
Well the transmission cross member is done. It's pretty simple and straight forward.
Just a piece of angle iron. The pieces of tubing that stick down below the cross member will be cut off and a small plate will be welded on to cover those holes.
And there's plenty of room around the drive line. As a side note last time when I was doing the exhaust I had to Frankenstein the exhaust to get it to fit between the frame rails. That's because I was using two different frames spliced together and the Ford frame was 3 inches narrower than the Ram frame. However this frame is actually a little wider on the inside which is why I have so much room between the rails. Sooo I guess there's no reason not to get some long tube headers now.
But the best part is that there aren't any jacks or blocks holding anything up anymore. So tomorrow I'll start the process of taking everything back off so I can finish that part up.
did i miss something? or is this truck gonna be 4 wheel drive now i thought i was crazy at first but the looks like a transfer case to me...so friggin sweeeeet
Yes sir! It is definitely gonna be 4 wheel drive. Actually this will be the first 4 wheel drive that I've owned. I'm just sick and tired of getting stuck in dumb places. Now once I finish this I can get stuck in places that are worth getting stuck in! Haha
hahahah I was thinking the same thing... All of a sudden there is a transfer case and I got really confused...
Yea, mounting the body will be interesting. I'd imagine that the body will end up sitting a little higher off the frame than usual. Well just have to see.
And as for TIG welding, it is a little more time consuming but I do enjoy it. However sometimes it's a challenge when my body is in an awkward position and I still have to have one foot on the control, the torch in one hand and the filler rod in the other. I've gotten fairly good at operating the control with my knee.
As for taking on any task, I'm sure there's something that I won't be able to do... I just haven't found it yet! Ha but no the engine harness and computer programing is something that is definitely out of my league. And with this engine being the one that uses an electronic throttle, variable valve time and the multi-displacement system it's a little more complex than the typical multi-port fuel injected engine.
But I do have some really interesting ideas for the fenders and stuff. But before I can start on that though I need to finish the frame and make some room in the garage.
Anyway back to the truck. I decided to go ahead and finish getting the rear end back together so I can go ahead and mount the rear suspension. I'm going to do this and then I will strip it down and complete all the welding.
