Sponsored by: Auxito
Wiring info for remote start
Old Sep 19, 2012 | 08:54 PM
Michael9280's Avatar
Michael9280
I added a remote start to my 2001 F150 XL. The remote starter says to use the negitive wire for the parking lights to flash, the form I got to wire it up says use the brown (positive) wire for the lights, its spliced into the brown & they don't work. Another question I had the door panel off, noticed that there is a harness going to the lock, is that for the dome light and door ajar light? Does it have power wires in that harness for power door locks even though it has no lock switches? Last question, I have to hook up the tach wire for the remoter start. The blue and green wire at the tach is the wire they say to use for the tach signal, does it stay the same color into the pcm from under the hood than out the pcm under the dash or does it change colors under the dash at the pcm?
Old Sep 30, 2012 | 01:32 AM
Michael9280
Took truck to professonial to check remote start, had to have replace do to brake shutdown in module being no good,causing it to not work right.
Ford'05HG
Nov 28, 2012 08:39 PM
caprang
Electrical Systems/Wiring
May 27, 2008 09:19 PM
stangdano
Oct 23, 2007 06:16 AM
skilife17
Nov 24, 2006 10:15 AM
stikk
Aug 27, 2006 04:39 PM
