Driving light
Old Sep 21, 2012 | 06:08 PM
Glockin' Bob's Avatar
Glockin' Bob
I know just what you mean, my BMW headlights have superb pattern and brightness.
My driving lights help out quite a bit on high beams, low beam pattern still sux. Really I think that the truck is in need of headlight replacement with HID projector headlamp assembly.
Originally Posted by RAPR
Macguy,
What wattage HID kit did you use? I installed a 55W hi/lo hid kit and it help out the low beams a good bit. the high beam is still less than perfect though. Then again, I am use to the headlights I had on my BMW that I traded in for this truck....those headlights were awesome.
Old Sep 22, 2012 | 11:07 PM
CornTruckDriver's Avatar
CornTruckDriver
Originally Posted by macguy
Rectangular usually doesnt project more than 20'. I'm looking for something focused straight, not wide and 60 plus feet path.
These project a lot more than 20 feet. They swivel a little up and down and the car wash puts them out of adjustment. I have seen the light in the trees quite a distance. not much but say 200 feet. Since light falls off at the inverse of the square it would be 4 times brighter at 100 feet and 16 times brighter at 50 feet. That combined with a new set of
SYLVANIA SILVERSTAR bulbs , it was quite an improvement.
Old Sep 22, 2012 | 11:15 PM
CornTruckDriver
Originally Posted by sdetweil
anybody double relay them? when the brights are on the driving lights are on, if upfitter 1 is on, else they are off..
that way they turn on/off with the brights.. I still wonder where all these people are coming from headed into town at midnight and later.. I know I am going home.. out of town.
which lights did you use?
Sam
Mine come on and off with the high beams when they are turned on through an up fitter. Low beams and fogs or high beams and drivers. I think they came from NAPA and I didn't install them myself.
Old Sep 23, 2012 | 12:05 AM
remhaust's Avatar
remhaust
Originally Posted by Ant1
No offense but I sure dont have 600+ extra dallars for just sum lights,that shiz better light up the airport runway for that kinda money.
Old Sep 23, 2012 | 12:11 AM
remhaust's Avatar
remhaust
Has anyone tried adjusting the headlights,mine worked awesome on lows,hardly ever turned brights on,then realized brights looked way high to me so adjusted down and alot better now.Anyone try any headlight replacements yet like recon projections,I see they have a few options?
Old Sep 23, 2012 | 09:51 AM
macguy's Avatar
macguy
Macguy,
I didnt like the HID kit for these headlights, as auto function when shutting down or turning on caused flickering when engine was off. So U replaced with PIA high output halogen. High is terrible as this is a single bulb design. My fogs however, I replaced with 9005 HID, 4300K. Its very good, but I need also a longer beam now.
Old Sep 23, 2012 | 09:53 AM
macguy's Avatar
macguy
Originally Posted by Glockin' Bob
nice.. what bulbs and mounting did you use?
Old Sep 23, 2012 | 05:44 PM
sdetweil's Avatar
sdetweil
nice.. how big are those? 4 inch? (I should walk outside and measure myself!)
Sam
Old Sep 23, 2012 | 08:29 PM
Glockin' Bob
I think they're 35W Xenon, threw away to box and stuff quite a while back. If you look in that area where I have them mounted, you'll see a hole. I made an L-bracket and bolted it through that hole and then mounted the light it a hole in the L-bracket.
Old Sep 23, 2012 | 08:30 PM
Glockin' Bob
Sam
I believe they are called 4" although the housing measures 5" diameter.
tincan1
Apr 1, 2019 06:51 PM
bgould1225
Feb 15, 2017 06:47 PM
carlhwv
6.7L Power Stroke Diesel
Nov 8, 2016 12:32 PM
adbscu
Dec 11, 2015 12:35 PM
GR$$N$
Feb 2, 2009 04:23 PM
