What Engine To Build...
Old Sep 18, 2012 | 08:42 PM
1975MudRat's Avatar
1975MudRat
Well like the title says what should I build? At my school we are required to do a senior project. I decided to build a motor, I would like to either build something with the big block bell housing or FE. What I'm looking for is a motor that will push 450TQ. What all should I do to this engine to make it push that much torque and what do you think the total cost would cost? I would like to have this done and in my truck by February? Is this possible for people with "some" experience?
Old Sep 18, 2012 | 08:47 PM
keiths78f150's Avatar
keiths78f150
If you are wanting those kind of numbers, you will need a 460. These numbers aren't very logical for something to do for a senior project. You will need a lot of machine work done by a professional. It will definitely be the most expensive senior project haha Look at a couple thousand at the machine shop, a couple thousand in parts.
Old Sep 18, 2012 | 09:08 PM
1975MudRat's Avatar
1975MudRat
Hahaha yea I bet I would pass tho ! I have been told those numbers aren't hard to reach with a 390.
Old Sep 18, 2012 | 09:13 PM
keiths78f150
550tq is a ton of power and WILL require machine work, big carb, new intake, block bored, big cam, etc.
Old Sep 18, 2012 | 09:18 PM
1975MudRat's Avatar
1975MudRat
How much time and money would it cost to build one that pushed 450tq?
Old Sep 18, 2012 | 09:49 PM
keiths78f150
Check this link out. 460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
This is just an idea of what I think you are looking for. You just gotta realize it takes money and machine work to get these old motors to that much power.
400-425HP 460ci
Intake System:
750cfm Holley DP professionally calibrated for your application
Edelbrock Performer Rpm Intake Manifold
Cylinder Heads:
D0VE heads with mild port job and chambers polished
(315ish/180-ish cfm flow @.600)
Intake valve size 2.08
Exhaust valve size 1.65
Stock rockers.
Short Block:
Comp Cam XE262H Hydraulic flat tappet cam or equivalent
(Specs:262/270 adv., 218/224@.050, .513/.520, 110 LSA)
Compression around 9.5:1
Stock crank
Stock rods with good bolts
Standard volume oil pump
Stock oil pan with windage tray
Exhaust:
1 7/8" headers to dual 2.5" pipes with H-pipe. Good flowing 2.5" Magnaflow mufflers or equivalent.
Summary:
91-octane. Keep redline to 6000 rpm.
425-450HP 460ci
Intake System:
Cylinder Heads:
D0VE head with mild port job, chambers polished, and port match
(315-ish/180-ish cfm @.600)
Roller rockers.
Short Block:
Comp Cam Custom Spec Hydraulic flat tappet cam or equivalent
Based on the Xtreme Energy Hydraulic Series
Intake Lobe 5443 and Exhaust Lobe 5203
(Specs:268/280 adv., 224/230@.050, .524/.544 lift, 110 LSA)
Stock crank
Exhaust:
Summary:
Old Sep 18, 2012 | 09:52 PM
VocaTexas's Avatar
VocaTexas
I've got a 300 sitting in the shed that I'm going to turbocharge in my next project. According to the numbers I've run, it should do 450-475 ft. lb. at less than 10 lb. of boost. That would be doable in a highschool shop class.
From the research I've done so far, the stock 300 parts are good up to 12-15 lbs. Some head porting would probably help the engine breath as the stock 300 head is pretty restrictive.
This engine doesn't fit your requirement for bellhousing, however.
Old Sep 18, 2012 | 10:02 PM
1975MudRat's Avatar
1975MudRat
Actually I have a 300 that I just pulled to replace with a 400. I just wanted something a little bigger.
What kind of hp and tq would a 351M push if I put on a:
Edelbrock Intake
Holley 650cfm Carburetor
Bore it .30 over
Cam with a .524/.524 lift and a 272/272 duration
Headers with true duals
Old Sep 18, 2012 | 10:54 PM
keiths78f150
I am not positive, but maybe 300 max. These 351m are boats. You could turn it into a 400 fairly cheap with a TMeyer kit and have your 300hp.
Old Sep 18, 2012 | 11:05 PM
1975MudRat's Avatar
1975MudRat
I have a 400...should I do the same to that? what will I get out of a 400?
Old Sep 18, 2012 | 11:11 PM
keiths78f150
If you want to make power from a 351m or 400, this is the guy to talk to.
TMeyer, Inc. Precision Automotive Machining
Old Sep 18, 2012 | 11:12 PM
LIF150's Avatar
LIF150
If you are planning on doing anything with the 400 then you need to head over to tim meyers website:TMeyer, Inc. Precision Automotive Machining and head over to the forum all about the 5.8/6.6L engines. People on this forum have done some pretty impressive stuff with them and tim would be able to help you in that department tremendously. Make sure you do your own research first but the 400 could be a good starting block.
Old Sep 18, 2012 | 11:22 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
450 ft-lbs of torque is easy with either an FE or 429/460
Josh
Old Sep 18, 2012 | 11:30 PM
1975MudRat's Avatar
1975MudRat
Josh
What all would need to be done to a 390 to get those numbers?
KAGAN21
Oct 14, 2017 02:17 PM
Mister_King
Mar 8, 2015 11:12 PM
Raider50
Feb 4, 2008 05:48 PM
RapidRuss
Apr 25, 2007 06:42 AM
Crimson_Moon
31
Sep 8, 2003 09:55 PM
