Dynamic Compression Help
Old Sep 18, 2012 | 02:55 PM
Lance Hogan's Avatar
Lance Hogan
I am working on a 302 rebuild for my father’s 1932 3 Window Coupe. I am writing to see if you guys can help me with Dynamic Compression and to see if I am calculating correctly.<O</O
<O</O
The engine is out of a 1996 Ford Explorer with the GT40 heads. I will be converting the engine from EFI to carb. I pulled one of the heads and measured the cc’s at 65. Further, I measured the piston (Sealed Power H816CP) down in the hole .010. Based upon this basic information and the information listed below, it looks like I need a camshaft with a 50-55 Advertised Intake Closing Angle to get my dynamic compression around 7.5 to 7.7 (I am using Pat Kelley’s Dynamic Compression Calculator). I have been told that a dynamic compression of 8.0 is ideal for a street engine. Am I calculating this correctly? <O</O
<O</O
Engine bore = 4.00<O</O
Crank Stroke = 3.00<O</O
Rod Length = 5.091<O</O
Combustion Chamber Volume = 65cc<O</O
Head Gasket Thickness = .039<O</O
Piston to Deck Clearance = .010<O</O
Dished Pistons (Sealed Power H816CP) = 4cc<O</O
Head Gasket Bore = 4.100<O</O
Any help would be much appreciated.
david campbell
1997 - 2003 F150
Jan 13, 2014 01:30 PM
Navistar Diesel
Jul 28, 2012 07:03 AM
DRRXR
55
Jan 21, 2012 04:31 PM
RA12625
Dec 3, 2010 09:05 AM
Lance Hogan
Sep 6, 2009 12:05 AM
