Horn
Old Sep 19, 2012 | 09:24 AM
bamaf150's Avatar
bamaf150
so does mine, doesnt work good either
Old Sep 19, 2012 | 12:09 PM
FordRun's Avatar
FordRun
i found that wire that hook to horn had a short in wire.
i cut it back some . tied my new horn wires into it,
seems to be working for the time.
way i tested it. unplug the yellow wire that plugs into horn.
i ran a piece of wire tied into yellow wire touch other end hot + battery
and i didn't even blow the horn as soon as i touch pos + the horn blew
you might want check that horn wire out.
Old Sep 19, 2012 | 01:01 PM
bamaf150's Avatar
bamaf150
I think the problem is in the button, not the horn or wiring
Old Sep 19, 2012 | 08:33 PM
kevin316's Avatar
kevin316
If you are getting a shock you may want to check the wiring.
No offense but now we know where all the butchered wiring comes from on all these trucks. Take a little time and at least use butt connectors (I hate butt connectors) instead of tape. Is that duct tape I see?
oneofakind97
Electrical Systems/Wiring
Nov 9, 2007 08:02 PM
oneofakind97
Nov 9, 2007 07:12 PM
mcne
Oct 13, 2005 09:37 PM
70RangerSister
Aug 1, 2003 12:23 PM
gtex
Aug 21, 2001 08:11 PM
