Gear ratio change
Old Sep 17, 2012 | 10:37 PM
FordYoungGun35's Avatar
FordYoungGun35
Gear ratio change
Changing the gears in a 96" f150 4x4 is it really a 1200$ deal? Changing to 4:10...
Old Sep 17, 2012 | 10:48 PM
impish's Avatar
impish
Two ways to do it. Neither is easy, or cheap. Replace entire rear axle assembly already set up with gear ratio you want, along with the front difgferential, which is a bear to do.
Or, replace ONLY ring & pinion gears in both front and rear. Few mechanics are trained to set up gears in the "integral" type housing used. Old Ford 9" was much easier (just an after-thought).
My guess, is, yes, it could easily cost $1200. I would not want to do it myself for less.
Hope this helps. BTW, 4.10s will greatly increase your engine's rpms at all speeds, use much more fuel, and wear out the engine more quickly. That's the downside of better acceleration.
impish
Old Sep 18, 2012 | 07:21 AM
Diesel_Brad's Avatar
Diesel_Brad
Yes. once you factor in gear, bearings and shim kit you would be looking at about $600+. Then factor in the labor
Old Sep 18, 2012 | 09:05 AM
rla2005's Avatar
rla2005
My last gear swap, 1997 Mustang GT, was about $400 in parts. That was new R&P (3.73), all new bearings/races and seals. Add in some bucks for gear lube, clutch packs (factory LSD) and a 12 pack of beer. I did everything in my home garage with no air tools. I have done several gear swaps in my lifetime so I knew what I was doing and had the proper tools, except for the big-a** airgun at the time.
You need to do front and rear as well as SERIOUSLY consider doing a LSD or locker on either or both ends, it is going to cost a pretty penny in parts alone. If the suspension bushings have much age on them then you may also run into changing those while you have things apart. All it takes is money..............but always remember: Do it right the first time!
Old Sep 18, 2012 | 10:09 AM
FordYoungGun35
Okay well y'all are all new to my threads so my plans are o rebuild the motor (302) and make a 4x4 lightning.. So the performance of a lightning just a 4x4.. And the 4:10 gearing which the lightning has will give mine the low end torque and get up and go feeling I'm looking for
Old Sep 18, 2012 | 10:38 AM
burnout400m's Avatar
burnout400m
You gotta pay to play!
Old Sep 18, 2012 | 11:12 AM
rla2005's Avatar
rla2005
I know exactly what your project plan is. The Lightning came with a 5.8L engine with a few factory go-fast parts. Your truck is a 4x4 with a 5.0L engine. Your plans for 4.10 axle gearing is bare minimum IMHO. Even with some mild mods that 5.0L is already at a low end torque disadvantage plus the added weight of the 4wd drive train. Even lower gearing or a stroker kit would even the playing field.
Diesel_Brad
Lightnings had HO 351 so better do some modding to the 302 just to get up to par
RTM
2009 - 2014 F150
Jan 11, 2019 01:48 PM
King-bRanch
2009 - 2014 F150
Nov 11, 2018 12:32 PM
almonyspm1
Oct 25, 2013 08:46 PM
fordtruckowner
2004 - 2008 F150
25
Mar 15, 2008 02:44 PM
OneTon4Fun
Dec 21, 2007 12:30 PM
