Sponsored by: Real Truck
Key-on wire
Old Sep 17, 2012 | 07:48 PM
acf6's Avatar
acf6
Key-on wire
Im just trying to locate a wire so i can hook up a relay to power my CB radio im going to install. What i need to find is the best place a wire that only gets power when the key is on is located, and what color it is. Thanks!
Old Sep 17, 2012 | 08:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Radio, fuse box, cigarette lighter... etc.
Old Sep 17, 2012 | 08:47 PM
dkf's Avatar
dkf
For the key on power I wired into my radio harness because I installed the CB in the same hole as the radio with a double ISO install kit. For the constant power on I tapped the cigarette lighter socket. The socket pulls out easily. Some guys run the constant 12v straight to the battery, I did not feel like snaking more wires. The antenna and CB install was enough of a PITA at the time.
My wiring adaptor diagram for the head unit says Red is the 12v switched power and black is chassis ground.
Old Sep 17, 2012 | 09:24 PM
acf6's Avatar
acf6
I noticed there was a white/blue wire taped off under the dash near where the factory trailer brake controller harness is. I havent tested it yet, but does anyone know if thats key-on only?
Old Jan 21, 2013 | 06:30 AM
acf6's Avatar
acf6
There is a white/green wire that is taped on the end under the dash near the trailer brake controller harness for customer access key on power.
SuperDutyFirefighter
Feb 25, 2014 06:57 PM
Ruin87
Apr 23, 2012 12:33 AM
cujo8
Mar 8, 2008 09:06 PM
CMT90BRONCO
1978 - 1996 Big Bronco
Sep 6, 2004 10:17 PM
stealth1
Apr 18, 2004 09:52 PM
