Steering Column Release Lever
Old Sep 17, 2012 | 07:37 PM
n4ynu1010's Avatar
n4ynu1010
Hello Everyone
I am looking for either NOS or Aftermarket "Steering Column Release Lever"
In My '89 XLT 5.0L 5Spd 2WD , the tilt wheel is actuated by pushing back on the Turn Signal Lever which pushes against this "Steering Column Release Lever" ( Dealer Name ) , which in turn lifts a tab at the center of the column to allow the wheel to tilt up and down , I am guessing it has some type of **** on the lever end that must break due to age , anyway I need that part , the dealer says no longer available , so is there a aftermarket version , I tried Dorman and no luck finding a listing , does anyone know of a aftermarket make or particular distributor of NOS , or is this something I would have to repair myself by modifying , going to go to the dealer tomorrow and print a pic so I can at least see what it is supposed to look like , if anyone has a pic and or part # that would help if you do not know where I can get one .
Thanks , Guy
Old Sep 17, 2012 | 09:19 PM
UNTAMND's Avatar
UNTAMND
Are you talking inside the column or external, and the lever you put your hand on and push backwards.
If its external, it's just a regular turn signal lever with a plastic flared end pressed on the end of it. Any one from junkyard should fit if it is from a ford.
Old Sep 17, 2012 | 10:55 PM
n4ynu1010's Avatar
n4ynu1010
It is internal , it is the lever that the turn signal lever actually presses against
Guy
Old Sep 18, 2012 | 01:06 AM
n4ynu1010's Avatar
n4ynu1010
Part # 3D544
No longer manufactured by Dealer , there has to be someone that has NOS or Aftermarket , I hope
Guy
FatBrian
13
Aug 12, 2007 05:22 PM
hoxiii
Feb 1, 2006 11:04 AM
Harlyred1
13
Feb 21, 2003 02:27 PM
denisontexas
Jul 16, 2002 09:46 PM
IES
May 3, 2002 07:36 PM
