Montana, I went with the 2". I havnt measured with a tape, but looking at it I gained at least 3-1/2", probably 4". Give it a few weeks and it might settle an inch.
That's what i figured, you were starting off with about 2" of spring sag so the 2" lift netted you 4" in actual lift.
They shouldn't settle too much, maybe an inch at most, those highboy spring packs contain mucho leaves.
Ride wise, would I be better off with a new set of stock highboy springs or 2" skyjacker soft ride?
My front spring packs sit about 2-1/4" off the bump stops right now, stock springs would probably give me enough leveling to make me happy with my little 35" tires.
I can't speak to the ride quality of new (Husky) oem springs, but as noted above the SkyJackers do tend to ride a bit on the harsh side despite their "Soft Ride" name, but imo they're no stiffer than the stock highboy springs.
If i were putting in the time, effort and money for new springs i'd opt for the SkyJackers over the oem's just to gain the additional 2" of lift.
Where are you going to get a NEW set of HB front springs?
The 2" lift is actually not much different ride wise than the stock sagging springs. The rear is actually a lot softer now. Ill be taking it out to hollister soon and will really put it to the test haha.
I agree with Montana, go with the 2" kit I just got, it looks a lot better with the 35's in my opinion. I'm on a phone but when I get to a computer I will post pics. I didn't take any pics during the install cause I was too focused on getting it done.
Thanks, They are 35's and still have lots of tread so keeping them for now. I know i have room to go with 37's but it would probably make it look just like it did before the lift. I like this extra fender gap so we'll see.
@montana, agreed. If I went with the 4" I wouldn't have installed it until I had at least 38's ready to go on at the same time haha.
I'm not really into mudding, I like to wheel on trails and terrain parks so this size will be perfect. I've made it up black diamonds before when it was stock, but now ill definitely be able to keep up with all my buddies with jeeps. I spent a lot of time on 3 wheels before because the springs were so worn out, stiff, and sagging. The new setup is definitely softer and articulates a hell of a lot more.
Boom! Thats what i want to do now So i measured from my bump stop and i have 2.5" between the bump stop and the top of the spring. So thats about an 1.5" in sag yes? I wana get that inch and a half back and go another 1 or 2 up after and im just loving the look of yours on the 35"s Is it possible to get some more close up pics maybe of like the front and then the back of the truck so i can get a better idea of the gap between the tires and the fenders etc. Sorry i thats asking alot but this just looks perfect... Also whats the distance from the top of the tire to the the fender?
Side note, you running wheel spacers? That on pic of what seems to be the back side of the rear axle looks like there is a spacer.
