Hey yall. Got all the chores done today that needed done, so a minute or two ago i started taking out the screws and such to get the inside of my passenger side door off.
Im sick of the key not turning in the lock. tried lubing it up and such. no luck
When loading groceries etc having to go to drivers side.. unlock. then use power lock to get it open.
Anyway. I got all the screws i see off. disconnected power window/lock. Do i need to just pull hard or do i need to reach inbetween to release those holds inside. I dont wanna just yank and break whatever plastic/metal pinch thing they have in there.
Any insight from the gurus are helpful.
Well back to the beer i mean workin for now
There are several plastic push pins all around the door panel. You have to pull out on the door panel to pull them all loose then once they are all loose lift straight up on the door panel.
