Bolt for belt tensioner is stripped!
I finally got a chance to get my crooked belt tensioner changed but after alot pulling on the ole ratchet the insides of the head of the bolt stripped out. Im thinking my only option is to get in there with a grinder and grind the head of the bolt off, slide the tensioner out and then turn the stud out with vise grips? Any advice is would be greatly appreciated. I slid whats left of the belt back on cause I need the truck. I cant stand the belt chirp any longer and the belt will probably let loose soon
Any tips, tricks, advice?
A couple things I can think of that you could try would be to use one of those broken bolt extractor sockets that have the teeth in them. Another would be to grind a couple flats onto the head and use a vise grip, wrench or crescent wrench. Other than that, I am guessing you're right, it is to grind the head off and deal with the stud after the fact.
I don't know if you would have the room or not, but welding a nut onto the stud is always a good solution too if you have the room.
Conventional "bolt-out" bolt extractor would work on a rounded head of a hex bolt. This one's a torx "hole" that's stripped/rounded. There are some new extractors that don't require as deep a drilling - something like Amazon.com: Alden 8530P Grabit Damaged Screw Remover 3 Piece Kit: Home Improvement . Might even work in a situation like this without any drilling.
Worst case, replace the whole bracket.
Well welding a nut on wouldnt be impossible. My try that. I dont think I could drill it. I had my ratchet on there and then a 1in wrench over the handle. Not the smartest way but bolt is really in there. Not messin with it till the weekend now cause I need the truck. Thanks for the advice.
I guess I wasn't thinking that it was the mushroom headed bolt that we were talking about. I can see how a broken bolt extractor wouldn't work so well in that case.
A couple of tips for getting that out, if you weld a nut over it use the biggest nut you can and weld it through the hole inside the nut (like at least a 1/2" nut if you can). Also when you're welding it in there concentrate most of the heat into the bolt by pointing the welder more into the bolt than into the nut. The nut will get plenty hot enough since it is the smaller piece of material.
Another tip that helps break free a stuck fastener a lot of times it to shock it good with a couple sharp hammer blows. This helps to break the bolt loose and free things up.
Or you could always remove the whole bracket and get it out where you can work on it. I would have to look for sure, but I don't think the bolt in question goes into the block. I am thinking it just threads into that aluminum bracket (which is likely why it is so frozen into place!).
Thanks for the tips guys. First chance I get I gotta jump in there. If I had a welder I probably would have done it by now. I just got a new job so its more important that I fix it now with the drive. I actually thought the bolt went into the block and not the bracket just because of how it looks to me. If welding the nut on doesnt work then its good to know it might come off with the bracket
That will be much easier to work on.
My belt tensioner is crooked as well. I will have to replace it as it is causing the belt on my alternator to jump a groove.
What is that two-pulley tensioner you speak of?
on
1 Post
bbf150
03-01-2019 05:29 PM
tiopet
04-02-2013 01:20 PM
