Positive traction.
Old Nov 23, 2011 | 04:54 AM
DieselBeast01's Avatar
DieselBeast01
Positive traction.
Are any of these trucks positive traction? Can someone tell me what the factory gear ratios are and how to find out what mine is?
Old Nov 23, 2011 | 06:45 AM
MCDavis's Avatar
MCDavis
Door tag axle code. If its a number and a letter then you have a limited slip.
the diff is a set of clutch packs and they are notorious for wearing out. If you have the limited slip then you can add a few ounces or friction modifier and possibly cure some of it if the wear isn't too bad.
Run a search for "door tag decoder" on here and you'll find a chart...id do it for ya but im on my phone and its not as easy.
Old Nov 23, 2011 | 08:13 PM
tbear853's Avatar
tbear853
19 — 3.55 non-limited slip — F-150
25 — 4.10 non-limited slip — F-150
26 — 3.73 non-limited slip — F-150/Mark LT
27 — 3.31 non-limited slip — F-150
B5 — 4.10 limited slip — F-150
B6 — 3.73 limited slip — F-150/Mark LT
H9 — 3.55 limited slip — F-150
Mine is a 3.55 with limited slip, hence the "H9" under "AXLE".
Happy Thanksgiving.
Old Dec 2, 2011 | 04:04 AM
DieselBeast01
So these trucks were just limited slip, and none of them had a positrac rear end?
Old Dec 2, 2011 | 04:23 AM
MCDavis's Avatar
MCDavis
Correct limited slip or open only. 09+ has an electronic locker but its only used in 4wd. Model year 12 will have a 2wd elocker option.
Old Dec 2, 2011 | 07:21 AM
hanklin's Avatar
hanklin
Positrac is a G.m product. Name only
Limited slip is Fords name
Same thing
Old Dec 4, 2011 | 01:47 AM
DieselBeast01
I checked mine, it is B6----3.73 limited slip.
Yahiko
Dec 20, 2012 11:33 PM
870
Apr 8, 2007 12:49 PM
Mike8623
Oct 27, 2006 07:33 PM
sillyp
Sep 11, 2004 02:52 AM
455 Jet
1997 - 2003 F150
Jun 20, 2003 01:45 PM
