Limited Slip
Old Apr 7, 2007 | 10:20 PM
870's Avatar
870
Question Limited Slip
Is there any letters in the seriel # that lets you know if it has limited slip?
Old Apr 8, 2007 | 12:17 AM
Dustin1690's Avatar
Dustin1690
Yes indeed there is go to the door jamb and on the sticker check under axle code if there is a code like H9 or H6 its limited slip lettter and number= limited slip but if its 19= or just a number its not unless someone has changed it out from non limited slip to Limited slip hope this helps
Old Apr 8, 2007 | 12:15 PM
Alta's Avatar
Alta
second place on the tag should be an L if its like the earlier ones. For example a 4.10 limited slip would read 4 L 10....on the tag, 373 would be 3 L 73....
Alta's Avatar
Alta
What are you working on?
Old Apr 8, 2007 | 12:49 PM
870's Avatar
870
1987 F-150 4x4 I'm going to buy next week.
