Sponsored by: Kumho
Wheel Offseet and Backspace - data gurus?
Old Sep 15, 2012 | 12:11 AM
nonrev321's Avatar
nonrev321
Hello,
Ref Vehicle: 1985 F250, Dana 44HD, 4WD. VIN: 1FTHF26L9FPB20202
This could be a tough one, hope someone can assist.
I am currently overseas and would like to purchase new wheels so they were there when I arrived at home. Could some data guru help me out with figuring out what the OEM Offset and Backspace is so I can order the correct wheels ……or what Offset/backspace I need for the new tires? Also will need the diameter of the hub opening I would need to accommodate the manual locking hubs.
New Tire specs: LT285/75R16 Approved Rim width: 7.5 – 9in, Measured Rim width: 8in, Section width: 11.65in, Overall diameter: 32.9in,
Tires presently on vehicle: 33x12.50R16.5 Specs: Approved rim width: 8.25– 10.5in, Section width: 12.4in, Overall Diameter: 32.6in
The factory original tires (data from window sticker) were: LT235/85R16. From the door sticker: Rims 16 x 6
The Lug pattern is 8 x 6.5.
I would like wheels as close to the original OEM specifications as possible as from what I’ve read this is what is optimized for best bearing wear and ride balance. Can anyone advise as to what offset and backspace rims I would need along with the diameter of the center hub opening .
Thanks in advance.
Rgds
nonrev
Old Sep 15, 2012 | 03:50 PM
nonrev321's Avatar
nonrev321
Further research still not turning up OEM offset and backspace but I did finally identify some Ford P/N for the wheels. If anyone out there can provide any info regarding offset and /or backspace on these Ford wheels I would really appreciate it. I’ve torn up Google search and haven’t found anything
E5TZ1015H, E5TZ1015B, E5UZ1015B, E3TZ1015S
thanks
nonrev
Old Sep 22, 2012 | 06:29 PM
Muffinman's Avatar
Muffinman
Just look up the Michelin tires for that year truck, they give you the specs for it there.
From what I found its 5"
nonrev321
Sep 15, 2012 03:49 PM
38COE
1947 and Older Ford Trucks
Feb 21, 2012 10:52 AM
Neil_E.
Large Truck
23
May 22, 2011 11:42 AM
'49 F3
Mar 18, 2009 07:19 AM
nitronigs
Mar 11, 2008 04:36 PM
