Flash-to-pass mod?
Old Sep 14, 2012 | 11:08 PM
bigwhitetruck01's Avatar
bigwhitetruck01
Flash-to-pass mod?
My '01 Ex does not have the option to "flash to pass". For those who don't know, FTP is pulling back on the column stick that toggles between high and low beams. Is my truck not functioning properly? If the Ex's don't normally have that feature, is there a mod for it?
Old Sep 14, 2012 | 11:13 PM
Stewart_H's Avatar
Stewart_H
There's something wrong with your switch or wiring.
You're sure your high beams are working?
Stewart
Old Sep 15, 2012 | 12:04 AM
bigwhitetruck01
High beams are definitely functioning properly. I've never had a lighting issue and from what I can tell, no modifications were made to the wiring associated with the lights. BTW, lamps are oem, no mods.
Old Sep 15, 2012 | 01:36 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
you need a new multi function switch.
Old Sep 15, 2012 | 03:15 PM
bigwhitetruck01
Any idea what part i should be searching for? There are a number of multifunction switches that came up in a search i just did.
Old Sep 15, 2012 | 03:25 PM
bigwhitetruck01
Motorcraft SW5548 Turn Indicator Switch : Amazon.com : Automotive
Could this be it?
Old Sep 15, 2012 | 05:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that's it. You might want to try an auto parts store. The last time I changed one it cost less than that one on Amazon, and it was in stock.
scottddove
Dec 14, 2012 06:06 PM
sflem849
Aug 7, 2012 07:23 AM
2 stroke man
Jan 25, 2008 09:14 PM
cravenc
1997 - 2003 F150
May 16, 2005 03:18 PM
