2001 excursion
Old Sep 14, 2012 | 12:06 AM
Oceanside Mike's Avatar
Oceanside Mike
2001 excursion
I have a 2001 6.8l excursion. while drving a few weeks ago, the gas gauge went slowly to full and the outside temp gauge reads 20 degrees less than actual temp. Is there a common link to both of these? saw a post from 2008 with simular problem, but could not find a response to see if others have had this problem?
Old Sep 14, 2012 | 03:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
So the gas tank wasn't full, I take it? Or are you concerned that the needle moved slower than expected?
Old Sep 14, 2012 | 07:33 PM
EXv10's Avatar
EXv10
Was that a one time thing?
Old Sep 16, 2012 | 10:37 PM
Oceanside Mike
no, the problem is on going, the gauge went to full and is stuck there, I would normally think it's in the sending unit in the tank, but with the outside air temp gauge acting up at the same time, makes me believe the two are tied together somehow.hoping someone has had the same problem come up before.
Old Sep 16, 2012 | 10:47 PM
Karlsgems's Avatar
Karlsgems
If they were connected, then your trip computer would reset also. A full tank gets you further than a half-full tank, right? Since you are not saying that the trip computer is resetting, im not sure theres any connection. The hot weather lately probably fried a wire.
Honestly, i spent good money having the overhead console fixed after i bought my rig, and to this day I think it was a waste of money. Just my .02
Good luck,
Karl
Old Sep 16, 2012 | 10:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
I don't see how those two things are tied together...except maybe in this coincidental situation. I would treat them as two separate issues that happened at the same time.
Old Sep 17, 2012 | 11:05 AM
AndrewWV's Avatar
AndrewWV
Could a random electrical issue cause both? I only ask because the instrument cluster quit working in a Voyager I used to own, and the culprit turned out to be the climate control switch. Those hardly seem related to me, but in that case they were.
Tcook911
Jul 23, 2014 10:01 PM
86stepsideF150
May 20, 2008 05:41 AM
wcurtis
Jan 12, 2008 09:38 PM
BroncRyder90
1978 - 1996 Big Bronco
Jun 27, 2004 06:33 PM
pkcoon
Jun 23, 2004 02:15 PM
