Underdash Lights
Old Nov 18, 2020 | 10:34 PM
77ford250's Avatar
77ford250
Originally Posted by EQCMCAT
The correct location is the ones that are within the circle that has three small pre-drilled holes with the single larger hole forward. That larger holes allows the light fixture mounting tab recess to prevent the fixture from moving side to side.
so just put a self tapping screw in the light?
Old Nov 19, 2020 | 08:18 AM
Aaron-71's Avatar
Aaron-71
Yes those are the correct holes.
The self-tapping screw goes in the slotted hole on the mounting tab. Leme see if I can get a picture... hmm... seems to be harder to find one on eBay than I thought.
You've got the location correct. Just need to get a photo for you for how they mount.
Old Nov 19, 2020 | 09:03 AM
77ford250's Avatar
77ford250
thank you I appreciate it
Old Nov 19, 2020 | 10:07 PM
EQCMCAT's Avatar
EQCMCAT
77 F250,
If you're not occasionally patronizing your local junk yard, it's a good idea to do so once in a while and when you do, and always get few Ford OEM sheet metal screws, fuses, light bulbs and etc. Be like a kid again with different stuff in your pocket coming out of the junk yard.
Old Nov 20, 2020 | 08:13 AM
Aaron-71's Avatar
Aaron-71
77 F250,
100% agree. Did this 3 weeks ago
Naganalf
Sep 12, 2018 06:40 PM
KOT390
Jul 1, 2017 06:43 AM
Broken40
May 2, 2016 02:00 AM
Larzon
Mar 19, 2012 10:31 PM
Justin's Green Truck
Jan 1, 2010 11:36 AM
