Differential (hog head) seal?
Old Sep 13, 2012 | 09:44 PM
Super Goob's Avatar
Super Goob
Noticed a noise on my 96 F250 when I put it in 4x4. Looked around and the passenger side axle where it goes into the differential (hogs head) is missing the bearing/seal whatever it is that goes there. Everything is still connected but there is ALOT of play in my passenger side axle as you can imagine. My question is what is this seal/bearing called? Iv'e found wheel seals, knuckle seals, etc. but I'm just really not sure what all I need cause nothing is there LOL. Is this a common problem or is there something completely screwed up here that caused it? Bought the truck for $800 about 2 months ago and I really don't know the history, just applying band aids as I go.
Old Sep 14, 2012 | 06:26 PM
garthneddy's Avatar
garthneddy
If your having some play where i think you are then you have bigger problems then a simple seal. I would pull that third member and inspect the internals.
Old Sep 14, 2012 | 06:41 PM
ptut42's Avatar
ptut42
Wait front axle our rear axle and are you talking about where axle shaft or axle tube hours into diff
Old Sep 16, 2012 | 09:38 PM
Super Goob's Avatar
Super Goob
From what I can find, its a oil seal and a bearing. Mine ain't there. I can see back in the housing. It's not cracked or anything, just a hole Like I said my axle is still connected and everything works. I'll check it out good this week.
Old Sep 17, 2012 | 06:34 AM
bashby's Avatar
bashby
What he said... front or rear?
dwkremer
Apr 21, 2018 03:18 PM
clhart426
Aug 29, 2011 12:46 PM
1ford1
Oct 19, 2007 11:09 PM
SoArkSI
Jun 13, 2007 03:05 PM
ramrod7373
18
Sep 21, 2003 09:22 AM
