Trying to understand glow plug system
Old Sep 13, 2012 | 06:26 PM
JT250's Avatar
JT250
Yes I have done research and read Wood-N-Things page.
I was reminded of my hard start when cold problem this morning. We got down to 60 here in OKC. It started but just took a little longer and had white smoke.
My engine oil temp reads 107. When I turn the key on I do not get anything from the side of the relay that goes to the glow plugs. I have 12v at every other post. When I give the pcm post a ground I can hear the relay click. Does this mean the relay is bad or what.
BTW I have had the hard start when cold for a while but have never seen the glow plug code until today. Will it throw a code because I messed with the relay, or because there actually is a problem.
I replaced the glow plugs in March when I did injectors. Motorcraft. I also have a new VC gasket and wire harness.
No I have not tried swapping the AIH relay yet.
Old Sep 13, 2012 | 06:34 PM
BigAlsPSD's Avatar
BigAlsPSD
Sounds like the relay may be good, but the PCM is not supplying the ground, basically the PCM is not telling the relay to kick on.
The code was likely from you grounding it out.
When you ground the relay, do you get 12V on the output of the relay? You might consider a momentary switch supplying a ground rather than PCM replacement.
Old Sep 13, 2012 | 06:37 PM
JT250's Avatar
JT250
I didnt test that....
If I do get 12v when I ground the relay then it means the PCM isnt sending the signal and is bad?
Old Sep 13, 2012 | 06:42 PM
landmobile's Avatar
landmobile
You should normally see a constant 12V at one of the large studs and both of the small studs. When the PCM energizes the GPR, it grounds one of the small studs which puts 12V across the coil and energizes the relay. If the GPR is clicking when you ground the PCM post, and there is no voltage on the large post going to the glow plugs, that means the relay is bad.
EDIT: If the ground isn't getting to the GPR, then it could be a PCM or wiring problem, as BigAl said. (looks like we were typing at the same time).
The AIH relay switches 12V to the air intake heater only and doesn't have anything to do with the glow plugs.
Chris
Old Sep 13, 2012 | 06:48 PM
JT250's Avatar
JT250
Chris
I know this but I was sure someone would ask if I tried swapping them to see if it would work. I have deleted the AIH so now it is a spare.
I will try grounding the relay and see if I get 12v at the GP post.
Thank you. Hopefully a bad relay.
Old Sep 13, 2012 | 06:49 PM
BigAlsPSD's Avatar
BigAlsPSD
It means either the PCM is bad, or another input, obviously not EOT because that is below the requirement to activate, is not good.
Seems like I only remember EOT and BARO(Internal to the PCM) coming into play though, but I will look through some information I have to see what inputs determine glow plug operation, others like AIT may come into play as well.
Old Sep 13, 2012 | 07:54 PM
JT250's Avatar
JT250
Yeah I read EOT and Baro
Old Sep 13, 2012 | 08:09 PM
1fixitman's Avatar
1fixitman
If I am not mistaken...The GPR will not send power to the glow plugs unless the engine oil temperature is less than 52 degrees farenheight. Just something to think about.
Dwayne
Old Sep 13, 2012 | 08:20 PM
BigAlsPSD's Avatar
BigAlsPSD
Dwayne
That is 55 degrees Celcius, or around 131 Fahrenheit.
Old Sep 13, 2012 | 08:32 PM
1fixitman's Avatar
1fixitman
Thanks for clarifying.
Old Sep 13, 2012 | 09:01 PM
carltonwebb's Avatar
carltonwebb
Did u see this writeup from years ago? It may help u with any lingering questions. My truck is one that quit supplying pcm ground. I have a momentary button that I mounted in the lip of the dash next to the steering column. When it is cold outside, i turn the key, count to 10 unless its really cold, and off we go.
Here is link.
https://www.ford-trucks.com/forums/7...pr-system.html
Old Sep 13, 2012 | 09:02 PM
fordpride's Avatar
fordpride
On a cold engine EOT should be a couple degrees different than ambient temp.
Old Sep 13, 2012 | 10:17 PM
JT250's Avatar
JT250
Here is link.
Thanks I will check it out
Old Sep 14, 2012 | 08:53 AM
JT250's Avatar
JT250
So I went out this morning when I knew the engine would be cold. Temp is 58 here. I tried to start and no dice. I wen and tested the relay and had .7v at the PCM input and nothing at the glow plug output. Then I heard it click and I had 12v at the PCM input. Then I jumped the relay and what do you know sh started. Looks like its jus the relay. Thank God! I wil swap in the AIH relay and get a stancor for standby.
Old Sep 14, 2012 | 08:57 AM
kawcrasher's Avatar
kawcrasher
Agreed. My Oil in the morning of 60 degree night is around 64. If your oil temp is 107 I would start their. I found the published for numbers for when things should happen are not always the most accurate.( At least for my truck) If nothing else you at least will have your oil temp sensor working for the other things.
