After driving from Houston to Denver I got in my truck to find my transmission is jacked or so I thought. Had some codes pulled and came up with p1302 boost calibration low! Anyone know what that is? The o/d light flashed for a few minutes. I can pull it into first and it has plenty of power. Shifts fine until drive. Then loss of power? 6.8 v10 2001 f-350
thanks for anyhelp given.
Jeff
It pulled that code p1302 along with p1832 transmission transfer case diff lock up solenoid circuit failure... would the p1832 cause my transmission to go into safe mode? My truck will switch into 4 hi and 4 low with no problems but still has the sluggish problem?
Seriously, why would you post a link to a list that doesn't include the code he posted?
Seriously.... after you already stated that it wasn't correct? Why would I state it again. Now the OP can confirm as the link states that it is ALL FORD DTC's.
