Changing Fuel Filters
Old Sep 14, 2012 | 10:36 AM
  #31
GeneLaw1's Avatar
GeneLaw1
Originally Posted by MisterCMK
The HFCM drain plug is typically stocked I have found. You can get it at an International dealer.
The fumoto valve is not.
OK, I will give a couple International Dealers and the Ford dealers a call see if they have it.
Old Sep 14, 2012 | 10:37 AM
  #32
MisterCMK's Avatar
MisterCMK
Do you want the part number?
Old Sep 14, 2012 | 10:38 AM
  #33
MisterCMK's Avatar
MisterCMK
2589259C91
6E7Z-9C082-A
Old Sep 14, 2012 | 01:23 PM
  #34
GeneLaw1's Avatar
GeneLaw1
2589259C91
6E7Z-9C082-A
Thanks! You are the man...is that the part number with Ford or International?
Old Sep 14, 2012 | 01:41 PM
  #35
MisterCMK's Avatar
MisterCMK
Uh, yes.
I think the top one is the International part number and the bottom one is the Ford part number. They are for a LCF truck.
Old Sep 14, 2012 | 02:03 PM
  #36
69cj's Avatar
69cj
The bottom one is a Ford number. Wether it's correct or not I can't tell you.
Old Sep 14, 2012 | 02:28 PM
  #37
MisterCMK's Avatar
MisterCMK
It is correct.
Old Sep 14, 2012 | 03:02 PM
  #38
Yahiko's Avatar
Yahiko
Handy thing to have to remove the covers
Ford Diesel 6.0 L 6.0L SuperDuty Oil Fuel Filter Socket
Ford Diesel 6.0 L 6.0L SuperDuty Oil Fuel Filter Socket | eBay
This socket does also fit the fuel filter cap.
So you don't crack them with an open wrench. Also with an extension you don't
have to be right under the HFCM when you remove the cap.
Sean
Old Sep 14, 2012 | 03:45 PM
  #39
GeneLaw1's Avatar
GeneLaw1
Sean
Thanks! I already got one of those babies...used it to change my oil last time I did it...
Old Sep 15, 2012 | 12:28 PM
  #40
GeneLaw1's Avatar
GeneLaw1
Well this was a complete fail. I just left the HFCM filter alone because some rod ( I believe the drive shaft) was in the way so I could barely turn the ratchet. Guess it has to be removed completely?? Then it got worse as I was trying to do the top filter, 2 pieces broke off of it, so now I cant even take the cap off. SMH...now what
Old Sep 15, 2012 | 01:04 PM
  #41
BPofMD's Avatar
BPofMD
Veteran: Navy
What tool were you using for the top fuel filter?
Same question for the lower fuel filter.... the main cap or the water drain? You must have 4 wheel drive, eh? It's that shaft that's in the way. To get to the main HFCM filter cap, you just need a longer extension...... go straight back until you can get leverage on it. And when you put new one on, don't over tighten it. Be sure to lube the "O"ring. With white grease NOT diesel fuel.
Old Sep 15, 2012 | 01:28 PM
  #42
GeneLaw1's Avatar
GeneLaw1
The top filter I was using an socket extention I had in the toolbox that fit in the opening. For the lower filter I was using the same socket I used for the oil filter...I believe its the 36mm...I got it off amazon. You are right, I do indeed have 4 WD, lol
This one:
Lisle 14500 Oil Filter Socket : Amazon.com : Automotive
Old Sep 15, 2012 | 01:30 PM
  #43
GeneLaw1's Avatar
GeneLaw1
For the water drain I was going to use a number 6 hex key...but I decided not too and wait until I got the upgraded drain plug for it.
Old Sep 15, 2012 | 01:37 PM
  #44
BPofMD's Avatar
BPofMD
Veteran: Navy
This one:
That is exactly what you should NOT have done!!! Now you get to go buy a new fuel filter cap. Maybe a strap wrench will remove it for you now..... someone really screwed you up by overtightening and underlubricating the "O" rings in both caps.
Old Sep 15, 2012 | 01:44 PM
  #45
GeneLaw1's Avatar
GeneLaw1
C'est la vie.....So ok def can tell I need a new filter cap. What kind of tool should I use in the future??
The dealer was the last entity to change those filters...from the looks of it, I will have to get them to change this one, I know nothing about using a strap wrench.
