BIGS 78 supercab build
Old Sep 13, 2012 | 10:00 PM
BIGS003's Avatar
BIGS003
So getting back to the frame. Originally i was really wanting to get someone to sandblast the back half of the frame. I went down the place that does it and hes saying 80 bucks and he doesnt think he can get everywhere....
soooo i asked around and i was told about this stuff called OSPHO basically wire brush/sand the big stuff off spray the ospho on let it sit. it starts foaming a lil but turns the rust back to iron i guess if i read it correctly. But after it dries you can paint right over it. its serves as a primer of sorts too.
The jug was 10 bucks and i used about a quarter of the bottle for the back half.
I wire brushed the frame lightly sanded the sides sprayed it with the ospho then preasure washed it later when it dried with some purple power.
I picked up some rustoleum undercoating to give it a shot.
It works great! goes on really thick and dries with a slight rubber texture. real cool i bought a few more can today for more coats. Also it is paintable.
Old Sep 13, 2012 | 10:14 PM
BIGS003's Avatar
BIGS003
Old Sep 13, 2012 | 10:22 PM
BIGS003's Avatar
BIGS003
I failed to post a picture of the new bed. Here ya go.
I cant wait to get the frame done and get that bad boy on there.
well guys and dolls thats all i have for you for now. your up to speed.
Ill post more as it happens. thanks again for the comments!
Old Sep 13, 2012 | 10:24 PM
keiths78f150's Avatar
keiths78f150
You got one hell of a start. I am definitely jealous.
Old Sep 13, 2012 | 10:40 PM
BIGS003's Avatar
BIGS003
Just wanted to briefly mention future plans. Here is a pic close to what id like to do with the paint.
Also this is probably more of a dream than reality but down the road id like to swap the 400 for a 7.3 power-stroke.
I need to get my seating arrangements worked out and id like to do some more audio work and install molded rubber carpet inside.
Old Sep 21, 2012 | 12:04 PM
BIGS003's Avatar
BIGS003
Got the bed on last night. bought some new bed bolts. the bed is jus sitting on there right now. i need to cut my new body spacers down to get the body line just right.
Old Sep 21, 2012 | 11:15 PM
BIGS003's Avatar
BIGS003
Alright progress! Its funny how accomplishing small tasks can make your day, and change you mood.
So yesterday we set the bed on and i ran to home depot and got some new carriage bolts for the bed.
and of coarse some beer for the project. makes all the lines straighter.
Here are the solid steel blocks that originally were on here.
so i got my new 3in spacers in yesterday. i knew i needed to cut them down before i started. no big deal. heres before and after i adjusted the spacers.
Old Sep 21, 2012 | 11:20 PM
BIGS003's Avatar
BIGS003
ok and after.
I got my fuel doors back on.
I ended up taking the filler neck hose from the front gas tank off my old parts truck and using it in the back. that took a lil time and patience but i got it hooked up.
Old Sep 21, 2012 | 11:23 PM
BIGS003's Avatar
BIGS003
So now i need to get my tail lights in and rewired. and get the tailgate back on and fix the tailgate handle.
Old Sep 22, 2012 | 01:10 AM
460 FORD MAN's Avatar
460 FORD MAN
Lookin good man
Old Sep 22, 2012 | 02:35 AM
rockdawg84's Avatar
rockdawg84
Great Job. Keep up the work. you're right the little things will make a big difference and before you know it you're done.
Old Sep 22, 2012 | 06:38 AM
tanman722001's Avatar
tanman722001
Your making good progress.Nice looking Supercab.Thats got to be my next truck.
Old Sep 22, 2012 | 08:57 PM
  #28
BIGS003's Avatar
BIGS003
Alright i hope someone can point me in the right direction here.
Im trying to redue my tail light wiring. I started after the plug that comes out of the end of the frame. I tested the wires. Yellow left turn green right turn brown running lights. Green and yellow for brakes. And green and yellow get 12 when in reverse. Now there is a black wire that gets nothing. No ground in the group.
Any wiring diagrams available?
I might just try to grab a new harness out of a truck somewhere.
Old Sep 22, 2012 | 11:08 PM
  #29
BIGS003's Avatar
BIGS003
ok i located a diagram on autozone.com im going to give it a shot tomarrow.
Old Sep 24, 2012 | 12:19 PM
  #30
BIGS003's Avatar
BIGS003
