Sponsored by: Real Truck
steering issue
Old Sep 12, 2012 | 07:44 PM
93F250's Avatar
93F250
steering issue
I have a 2002 F250 4wd reg cab 5.4. It is all over the road. New ball joints. New steering stabilizer. Everything in the front end feels tight when I check it off the ground. I turned the Allen screw on the steering box in until it wouldn't turn any more. It has 62k on it. Has had a hard life in those miles. Towing, plowing and tons of short trips. I don't know what else to check. Any ideas?
Old Sep 14, 2012 | 06:48 AM
redford's Avatar
redford
FTE Leadership Emeritus
How about an alignment?
Old Sep 14, 2012 | 06:50 AM
projectSHO89's Avatar
projectSHO89
Check the steering gear for excessive play. If you tightened down the setscrew all the way, you likely aggravated the problem.
Old Sep 14, 2012 | 07:38 AM
drey04's Avatar
drey04
^^^^ what he said. Tightening that screw (aka the lash adjuster) causes the pitman shaft teeth and rack teeth to mesh together tighter.... therefore reducing lash/loose steering. About a 1/4 turn is all you need.... any more and you can cause the steering gear to bind up and possibly break gear teeth.
jgavac
Jun 14, 2017 05:24 PM
Fordication
Jul 19, 2016 10:19 PM
JMyers0901
Feb 25, 2013 05:27 PM
BLACK350/6.0L
Oct 28, 2008 07:59 PM
AlM
1978 - 1996 Big Bronco
Oct 19, 2002 08:52 PM
