5.4ford vs 6.0 chevy
Which do you think could pull more with all things being the same as rear ends trannys (manual) etc the 5.4 or the 6.0 the 6.0 has 40more hp and 10more ft of tourqe but it makes all of its tourqe at 4someting rpm while the 5.4 makes all of its tourqe at 2500rmp so which do you guess think would win?
on
The GM 6.0L doesn't make "all" of it's torque at 4 something rpm. It actually makes over 300lb-ft from 1000rpm all the way up to about 5500rpm. It peaks at 4000rpm. The 5.4 doesn't make 300lb-ft until about 1500rpm and drops below 300lb-ft at 4400rpm. The 6.0L has a much flatter torque band.
You should always 'spec' your truck to have a good 20-25% extra capacity then you think you will need if towing / heavy hauling is going to be part of the trucks life.
That's why Ford has the SuperDuty trucks with the fine 6.8L V-10 and the mighty PowerStroke Diesel!
Have you been to a Chevy dealer lately? Don't you know the engine is designed to piston slap? It's actually a clever feature designed to let you know when your truck has warmed up! I gotta hand it to GM they took the best small block V-8 ever made (the 350) and added more cubic inches and another feature, makes me feel all warm and fuzzy inside.
from??????
Now, anybody have an engineering reason for:
"Like a rock"
Apparently they wanted the trucks to stay on the dealer lot so they made them "like a rock" this way they are camoflaged and way to heavy to move.
I kind of like that piston slap when I pull up to one at a stop light, it has a nice rhythm to it, kind of like ''thumpin' '' for chevies.
dieselburner6.0
08-17-2006 02:16 AM
forddytube
Computer Chips & Tuners
08-10-2003 12:44 PM
stover007
17
04-10-2003 11:41 AM
