Can someone please enlighten me on which years and models had divorced and non divorced np 205's. And which years did they do 203's vs 205's? I have a 78 F250 (back home so I cant go crawl under it) but im looking for a non divorced np 205.
73 - early 77 had divorced transfer cases in the F250's. Not sure about the lowboy's made in those years. Late 77-79 had married in the F250's. Always married in the F100-F150. Not sure about 203 or 205. I think it is random. My 78 F150 had a 203. My other 78 F250's have 205's.
yeah Im putting a doubler in my cj behind an ls 6.0 thats why im so curious haha. What is needed to bolt the 203 to the 205? Any adapters? Or is it a bolt on?
On a doubler only the low range part of the 203 is used. couple outfits make doubler kits.
Going into a CJ? keep in mind the length of the drivetrain. Its been done but makes for a short rear drive line unless you have allot of lift.
Is that going to be a ford 6.0 or a GM 6.0?
If Gm you will need a gm 203 and the correct adapter to go with what ever tranny you use.
For a Ford 6.0 your going to need ti find an adapter to bolt up a 203 to what ever tranny the power stroak has...that could be tricky. Ford dropped the 203 and the 205 in 79.
Yeah i was looking at the Offroad Design. Its a chevy ls 6.0 but the jeep is being comp cut and the axle slid back and front forwards with 3 and 4 links. But its still a long setup... But $1000 is cheaper then $3000 for an atlas and adapters!!
My 78 f250 had a full time 203 that was converted to part time.
I also have a '78 F250 with no locking hubs so i always thought it was full time. But i can put it in 4x4 in the cab and thats when it locks in.....i would like if someone would explain which t-case i have and how it works? Thanks
Also guys, what are dana 70s worth? I am using the 60 front but a 14 bolt rear. Someone wants my 70 but I have no idea what they are worth? Its complete.
