question about heads
Old Sep 10, 2012 | 04:59 PM
daleyboy's Avatar
daleyboy
I have a 88 f250 with a 7.3l idi. The question is, is the heads from a 6.9l the same as my 7.3l ? will they interchange?
Old Sep 10, 2012 | 05:09 PM
Phy's Avatar
Phy
They don't interchange. The 6.9 has smaller head bolts.
Old Sep 10, 2012 | 05:13 PM
daleyboy's Avatar
daleyboy
Thanks, that cleared that up
Old Sep 10, 2012 | 11:01 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Phy,
Are you sure? I thought I heard that all IDI heads are the same. I just had mine rebuilt and the head shop cross referenced the same heads for both motors, but that is no guarantee! It is true that the block has different thread size on the 6.9 (7/16") vs the 7.3 (1/2") but that doesn't mean that the heads are different, the bolt holes on the 7.3 head are definitely big enough to accommodate a bigger bolt, if the 6.9's are also that would mean that a 1/2" bolt should fit through. I am not certain, but I do know that the 7.3 valve train will bolt into the 6.9 head.
I am sure that someone will set me straight.
Old Sep 10, 2012 | 11:10 PM
91dirtydiesel's Avatar
91dirtydiesel
Thought some coolant passages were different too? Here is a 7.3 bolt vs 6.9
Old Sep 10, 2012 | 11:22 PM
akamacgyver
Clueless spectator!
So the length in itself would be a problem, I know for sure that all 17 7.3 head bolts are the same length, so I would think that I am wrong here.
Thanks Dirty, BTE good news on my cavitation "non" issue, I am about to write up the story in my head gasket repair thread. It's a million yucks!
Julian Kalamaha
May 22, 2018 09:27 PM
Mikey Oldaker
Jun 3, 2012 12:48 AM
fiftyfordfloored
May 27, 2012 10:11 PM
86f250XLT-4x4
Aug 8, 2011 09:32 PM
jmerritt
Nov 2, 2007 08:59 PM
