6.9 heads
Old May 21, 2018 | 01:38 PM
Julian Kalamaha's Avatar
Julian Kalamaha
6.9 heads
i got a 1986 f250 6.9l and Im trying to find better heads for the motor or some how make the heads stronger. Do you know where to find preformace heads for a 6.9?
Old May 21, 2018 | 02:36 PM
DarkOverCast's Avatar
DarkOverCast
The stock heads are plenty strong, 87 6.9 heads were the best because they use the same valve train as a 7.3, 83 used a different precup other than that they are all the same and plenty strong.
If your blowing head gaskets then you need head studs
Old May 21, 2018 | 07:32 PM
genscripter's Avatar
genscripter
Why do you need stronger heads? What are your plans?
Old May 21, 2018 | 07:56 PM
cadunkle's Avatar
cadunkle
I'm not aware of any head breakage epidemic. Precups crack from heat, but cracks are OK to run so long as they're not past the fire ring.The only difference from 6.9 to 7.3 heads is the head bolt hole size, and possibly length of the lower head bolt bosses. 7.3 heads had plugs in some coolant passages, some people drill them or remove the plugs entirely. Not sure what the advantage of one way or the other is.
Old May 22, 2018 | 10:58 AM
Charmalu's Avatar
Charmalu
I saved this link a while back, they make new Cylinder Heads if you want to go that route. Probably a bit pricy.
They use to have 6.9/7.3 heads listed.
New and Remanufactured Diesel Cylinder Heads, Blocks, Rods and Castings
Charlie
Old May 22, 2018 | 09:27 PM
genscripter
Charlie
I bought from these guys. It was $550 per head, and they came fully dressed. My local shop said NO ONE could beat that price for a complete set of heads. so far, they are still going strong.
daleyboy
Sep 10, 2012 11:22 PM
fiftyfordfloored
May 27, 2012 10:11 PM
white73
Feb 2, 2007 10:10 PM
GPSMatt
Nov 4, 2005 08:01 AM
hellraiser
Mar 15, 2003 12:38 PM
