Aerostar Ford Aerostar
Charging System Failure
Old Sep 22, 2012 | 10:56 PM
RojoStar's Avatar
RojoStar
Originally Posted by Muffinman
It's a reverse thread pulley...
Sorry, WPS 3G is right hand.
Old Oct 13, 2012 | 06:30 PM
waterbear's Avatar
waterbear
just to confirm the Products ID and not to blame or hurt anybody or anything. Some more rocky horror pictures from the blow alt below.
Remember that Unit has had several Oil showers before everything has flown off. There is a kind of Glue on the Surface left (picture above) that once had contact to the Impeller. Would have the penetrating Oil chemicaly decomposed this Glue? Imagine the Shovels have lifted off at a sufficient Drag because of this..? However, the little rear Bearing is in fact floppy with lots of play.
lbnl, perhaps some headbangers may have plunge a Nail into the Housing.
In a Conclusion, i remain suspect but i do not want to judge this Product as bad. The WPS has a clean finished Housing, other then the many preserved mummy-style like Remans available out there. It spins very smooth with no roughness and has never begun to squeal or hum. It comes with an inoxydable metallic Pulley and a HD grade Regulator. Nevertheless some upgrades could perhaps improve the reliability (Bearing).
Alternator the IIV - Remanufatured ACDELCO from Wholeseller Closeout (65bucks) sold by Rock
This remanufactured ACDELCO has a rough felt spinning, right out from the Box. It does squeal a bit and i suspect that it will obtain a weak Condition early. At least i hope he will fail upon announcement, giving a chance to get a deadline for replacing the Bearings before everything blows off.
Back on the Road and runs like a champ.
97' XLT RWD, 3.0L Vulcan, 112700miles
Old Oct 13, 2012 | 10:03 PM
96_4wdr's Avatar
96_4wdr
the "rough" feel spinning new is probably the new brushes against the new split rings. they have to wear in to each other to make a quiet smooth running surface.
kind of like a new marriage couple, takes time to wear off the rough edges and high spots.
Old Oct 14, 2012 | 01:45 AM
xlt4wd90's Avatar
xlt4wd90
Split rings are in the old DC generators. The whole point of alternators is that they use continuous rings for better reliability and longevity, and they generate AC, which have to be rectified by rectifiers (diodes).
Still, new brushes may not feel smooth on continuous rings.
Old Oct 14, 2012 | 06:33 AM
96_4wdr's Avatar
96_4wdr
slip of keyboard, split rings.
meant to use slip rings, still old school
you can tell us old duffers.
40 years ago, turned my built solid lifter cam SB 283 Chevy to 6k rpm+, generator commutator turned into shrapnel.
Wife's new turbo BMW doesn't redline until 7500 rpm
if you dig into that WPS or AC/D alternators, you'll find the components are made in China. The Chinese are not know for their machining talents or quality control.
Friend of mine bought a Chinese made AK-47 semi auto. Think came apart firing it, took away part of his face. Bolt mechanism shattered.
Cheaper is not always better.
Old Oct 14, 2012 | 04:36 PM
waterbear's Avatar
waterbear
I must correct myself. it's not felt rough, it's a rumble. Best felt, when holding the Alternator in one hand and the pulley spinned by the other.
Those Products may have been in storage for a long time. Grease gets sticky inside the Ball Bearings over the years. In use, the Grease can return to a better condition by heat and motion. Worth a try to remove the Belt from the Alternator after a period of use and examine the spin.
O/T 96' XLT 3L for sale in the neighborhood, all in blue.. 200$, Seller want to get it rid of his loan quick as possible..hmmm.
Melonmuziq
Electrical Systems/Wiring
32
May 25, 2018 12:15 PM
Tekmon1
Dec 13, 2017 10:29 AM
midniteblue
1978 - 1996 Big Bronco
Aug 31, 2015 03:32 PM
timbersteel
Nov 20, 2008 06:26 PM
hillnickshaulin
May 29, 2005 10:15 PM
