Time for head studs?
Old Sep 25, 2012 | 10:22 PM
  #61
DieselVol's Avatar
DieselVol
Originally Posted by bismic
If anything I would think it is slight lifting at max boost or WOT conditions.
Well if I didn't tear it up tonight, (it crossed my mind how ironic it would be to blow the gaskets while trying to test my gaskets) I think I'll be all right for a while. I'll keep monitoring for a while and see if it changes. Thanks for the help!
Old Sep 25, 2012 | 10:28 PM
  #62
bismic's Avatar
bismic
A few test drives will not do it (lift the heads). IMO leaking head gaskets is a process that doesn't happen all at once unless it is helped along with very high boost or fluid in the cylinders. It is the nature of TTY bolts to stretch progressively. And afterall - the puking was there before the testing.
Old Sep 25, 2012 | 10:48 PM
  #63
DieselVol's Avatar
DieselVol
Probably true. There was the thought that it was just overflow from the degas, but it does look like its just splattered all over the driver's side manifold. Are you advising me to go ahead with studs or just keep on driving for now? I know which one I'd prefer, but as I said, I plan for another 100k.
Old Sep 26, 2012 | 02:47 AM
  #64
bismic's Avatar
bismic
I would at least watch the pressures and learn what causes it to rise past 12 psig and avoid those conditions. When that interferes with the performance you want from the truck, then it is time for head studs. Also would advise at a minimum limiting the boost to 28 psig, That could be sooner rather than later - it just depends on your needs and how much the bolts have yielded. In the meantime, I would locate a reputable repair shop and machine shop and maybe start getting the parts. I would also probably repeat the combustion gas test at least once more. The damage that you want to minimize (that can be caused by a slow leak) is corrosion of the head and block surface. It can also lead to corrosion in the turbo.
You may not want to hear it, but the Edge Juice is not all that friendly with the head bolts and the transmission.
Old Sep 26, 2012 | 07:29 PM
  #65
DieselVol's Avatar
DieselVol
Yeah, the plan had been to get studs and an SCT tune and just use the Attitude monitor as just a monitor. Some more data from today: I warmed it up well, let off the pressure, then continued to just drive like I always do. The pressure never went above 1 psi. I spoke with my mechanic today and gave him the same data as I gave last night plus the new data from today. The plan from here is to watch the fluid level in the degas bottle. If the levels don't drop, we'll continue to follow it. If they do, it's stud time. What will make the difference in my opinion, is the next time I hook up to the Bobcat. I suspect that is when it puked and it'll probably do it then again.
Old Sep 26, 2012 | 08:46 PM
  #66
Sullid01's Avatar
Sullid01
This is what a lot of folks find - puking only under heavy load. See what happens the next time you are towing - I'm still hoping for you, but your pressures are high without much load on the truck (just crazy driving).
Old Sep 26, 2012 | 08:54 PM
  #67
DieselVol's Avatar
DieselVol
I wonder about that: is there really any difference in pressure inside the engine, no load vs heavy load, when the boost is 30 psi? My opinion is that the boost is generating the pressure and the load is not really a factor in comparison. I may be wrong.
Old Sep 26, 2012 | 09:00 PM
  #68
bismic's Avatar
bismic
Actually the timing plays a big role also. It is the cylinder pressure that lifts heads. High boost can contribute to high cylinder pressures, but not always.
Old Sep 26, 2012 | 10:55 PM
  #69
DieselVol's Avatar
DieselVol
See, I was right about being wrong.
Old Sep 29, 2012 | 06:22 PM
  #70
DieselVol's Avatar
DieselVol
Well, that didn't take long...
To make a long story short, big pool of fluid under the truck, degas bottle dropped an inch in 2 days, degas pressure hits 20 psi in an easy 20 minute drive. It is time for studs. My Tuesday night "test" finished off the gaskets. Though inevitable, I had hoped to make it to spring.
Old Sep 29, 2012 | 06:50 PM
  #71
bismic's Avatar
bismic
Waiting on fixing a head gasket leak causes coolant gelling to be a possibility (if you are using Ford Gold) and it causes corrosion damage on head and block surface to have time to get worse.
It is better to fix it quickly when you see the evidence.
Old Sep 29, 2012 | 07:08 PM
  #72
DieselVol's Avatar
DieselVol
Thanks. Calling my mechanic Monday.
Old Sep 29, 2012 | 07:24 PM
  #73
Sullid01's Avatar
Sullid01
So what was your "test"? Time to switch over to an SCT tuner and Matt's tunes. Good news is you will love them, esp the SRL++ for studs. The bill is going to hurt though - I still wince a bit every time I come across it in my truck folder.
Old Sep 29, 2012 | 08:15 PM
  #74
DieselVol's Avatar
DieselVol
The test was all the 30 psi boost stuff from the night I hooked the coolant pressure gauge up to test for gasket leaks. The mechanic said $32-3500 for the studs and install. I'm confused about the "custom tunes". Do they get data from your truck to make it truly "custom", is it just custom since it's only available from the particular person who wrote it?
Old Sep 29, 2012 | 08:19 PM
  #75
MisterCMK's Avatar
MisterCMK
Call Matt and get the SRL Extreme.
