Hinge pin slop
Old Sep 8, 2012 | 03:29 PM
aussiecowboy's Avatar
aussiecowboy
Hinge pin slop
I'm at the point of trial fitting the doors for alignment and gaps etc. The upper hinges are quite worn, to the point that the pin slips in and out by hand and has some play. Has anyone else had this problem and found a solution? All I can think of is to add some blobs of weld to the pin and grind it back to give an interference fit.
Old Sep 8, 2012 | 09:39 PM
52 Merc's Avatar
52 Merc
Oversize pins are available for exactly your situation. You may need to ream the hole to ensure it's round again and the correct size for the new pins.
Old Sep 9, 2012 | 02:03 AM
aussiecowboy
Fantastic! Any idea who sells them?
53FOPAR
23
Dec 5, 2017 10:15 PM
Usmc6.0
May 31, 2017 01:22 PM
windsor8689
Feb 15, 2011 09:26 PM
sancochojoe
Apr 1, 2004 06:47 PM
billb7984
Nov 16, 2002 04:27 PM
