I want crank/no start
Old Sep 8, 2012 | 01:54 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Bout to fire up my new motor. I want to crank no start to prime the oil system but I want to monitor ICP and the like with AE. So pulln the 42 pin is out and I couldnt be bothered with the IDM fuse. Is there another easier option
Old Sep 8, 2012 | 01:56 AM
BigAlsPSD's Avatar
BigAlsPSD
Unplug the CPS.
Old Sep 8, 2012 | 02:39 AM
ChunderDownUnder
Thanks Al. Well Im not building ICP. batterys are stuffed now so I will charge overnight and give another go in da morning
Old Sep 8, 2012 | 04:16 AM
BigAlsPSD's Avatar
BigAlsPSD
Does it read with the ICP disconnected?
Could be some trash in the IPR.
Old Sep 8, 2012 | 05:02 AM
ChunderDownUnder
So you are saying disconnect the icp as well ?? Brand new motor - full rebuild new ipr/HPOP, new sticks new everything
https://www.ford-trucks.com/forums/1...tor-build.html
Old Sep 8, 2012 | 05:39 AM
BigAlsPSD's Avatar
BigAlsPSD
Disconnecting the ICP sensor might just help it start, as it will signal the injectors to fire because it will be using a default value. It can take a while to get the oil flowing honestly, I'm sure once your batts are back up, you will be fine.
Old Sep 8, 2012 | 06:35 AM
ChunderDownUnder
bout to hit the sack. will charge the bats and try again tmorrow. Thanks Al. If no go I will start a new thread
Old Sep 8, 2012 | 06:47 AM
tommyl's Avatar
tommyl
How about just jumping the starter solenoid on the pass. fender?
LCA078
49
Dec 29, 2018 12:47 PM
dogfennel
19
Apr 16, 2014 07:28 PM
LittleBlue94
Apr 26, 2013 09:30 PM
scatgo
Aug 29, 2010 07:22 PM
KTofCO
33
Nov 6, 2006 08:22 AM
