96 460 ecm/pcm
Old Sep 7, 2012 | 11:03 AM
Blue Bandit's Avatar
Blue Bandit
96 460 ecm/pcm
I have a 96 f250 w/ the 460. the truck was orinigally from cali
the ecm/pcm went out and im having problems find the correct one
the guy that works on my truck called a guy her knew at a dealership and ran a nationwide search and found none. just needing to know if anyone knew where i could get one?
do the pcm have to be a california emmisson one?
im lost.
part number: f6tf-12a650-amd
Old Sep 7, 2012 | 12:19 PM
UNTAMND's Avatar
UNTAMND
Umm, dumb question but have you called the parts store.
Advance
Autozone
Napa
Carquest
You don't need to buy stuff from the dealership. Half the time they get parts from the local parts store anyway.
Old Sep 7, 2012 | 01:30 PM
RIKIL's Avatar
RIKIL
im lost.
The part number is a start, there is also a code, I've heard the code called different things but I think it's called a strategy. You won't need to worry about getting a CA specific computer but you will need to make sure you get a computer that is made for your size motor and the same type of transmission you have.
There are codes like A9L or A9P, and I think there may be 4 letter codes as well but that's what you need to match.
Notice on this page the part number then the 'other part number'. The other number is the strategy you need to match up - F6TF-12A650-KE F150 Bronco ECM 5.0 1996 ECU VEE4 | eBay
Old Sep 7, 2012 | 03:06 PM
UNTAMND's Avatar
UNTAMND
Being a California truck and a 460, it may be mass air, which may be harder to find.
No other ecu can be used because a 302 mass air ecu just won't work. If he had a 351 it would probably be just fine but 460 is just too many cubes and injectors are bigger, I'm sure it wouldn't be happy if he used that ecu on it.
Call the parts stores and ask.
Also let us know if it's mass air or not.
Old Sep 7, 2012 | 06:36 PM
rla2005's Avatar
rla2005
It would help to also have the Calibration Code listed on the door jamb as well as the part number you listed.
Old Sep 7, 2012 | 06:42 PM
subford's Avatar
subford
Here is one for sale:
1996 FORD F250 PICKUP ECU
When you search for it do not use the center numbers. All computer have the same center numbers so most places drop them on the net.
Just search for "F6TF-AMD".
Old Sep 11, 2012 | 12:16 PM
Blue Bandit
thanks for all the responses. i was out of town all weekend.
it wasnt the mass air, it was the actual computer. Now the guy had called every parts store, they dont have it.
so we have one from a different truck that he is going to try to re program has anyone heard of doing that? what kind of problems would i run into if we were to do that?
Old Sep 11, 2012 | 12:23 PM
RIKIL's Avatar
RIKIL
First thing to ask: have you done this before?
I wouldn't say I have heard of this (might be possible) but I see most people just end up modifying the existing and not trying to reprogram the whole thing.
Old Sep 11, 2012 | 12:31 PM
subford's Avatar
subford
It would not make any difference what program the computer is running if the computer hardware is not the same.
You would have to have all of the parts inside the computer at the same address as the program that is running and also you have to have all of the same pins in the plug and hooked to parts inside that are at the same address or wired to the right pin of another chip for it to work right.
There should be a hardware code on the plug of the computer saying what hardware it has and what hardware arrangement it has.
An example of a hardware code would be "EFI-SD20B".
Old Sep 11, 2012 | 01:01 PM
Truckin Bob's Avatar
Truckin Bob
In other words......... this is a fuster cluck in the making.
Bob
Old Sep 11, 2012 | 01:31 PM
UNTAMND's Avatar
UNTAMND
Unless the guy has some ford equipment or some chip burning equipment, then he's gonna fail at "reprogramming" it.
I wasn't trying to imply that it was the mass air, I was asking if the truck was a mass air truck, because you can't put a speed density computer in place of a mass air computer, no matter how you try to reprogram it.
If your truck is mass air, then you could potentially use a mass air 302 computer.
But if your truck is sd, then nearly any sd computer can be used ( not a 300-6) if reprogrammed.
Old Sep 11, 2012 | 01:43 PM
RIKIL's Avatar
RIKIL
can you post some pics of any letters or markings from your computer? I'd hate, in any way, to insinuate that a mechanic doesn't know what he is doing *cough* but I bet the guys here can help out pretty quick.
Old Sep 11, 2012 | 04:19 PM
Conanski's Avatar
Conanski
OBD-1 PCMs are not reprogrammable for all intents and purposes, technically it is possible but not with any tools your average mechanic would have and not without some very specific knowledge and electronics equipment. It's also very likely that your truck is MAF and it could even be OBD-2, and given that it doesn't appear that your mechanic knows any of this I think we need to go back to the top here and ask.. how exactly has it been determined that your PCM is indeed dead?
Old Sep 11, 2012 | 06:23 PM
subford's Avatar
subford
Going back to the first post.
From the number you posted "F6TF-12A650-AMD".
This is an OBD-II computer and it fits a MASS truck.
I am not an expert on OBD-II systems but I have heard that they can be reprogramed at the Ford dealer.
I do not know if this is the whole program or just the look-up tables they change.
I also do not know what truck you are getting the computer from.
I also do not know if all OBD-II computer have the same insides and pin-outs. This was never the case with the OBD-I computers.
If everyone of the OBD-II computers are identical hardware wise both in pin-out and hardware inside and they can replace the whole program along with the tables then yes that computer you have found will work.
cajohnson
Sep 26, 2014 10:41 PM
riggermortis
Jun 16, 2010 10:02 PM
Ibuildembig
Jul 18, 2007 09:27 AM
Rediranch_too
Computer Chips & Tuners
Jun 23, 2006 12:02 PM
masterbeavis
Dec 23, 2002 10:52 PM
