'96 -'97 460 MAF ECM type
I have located (by internet) the 460 mass air intake system in a bone yard in California. The man says he also has the ecm from the same truck, but the numbers on it do not quite match what I have found is the normal unit. This, by itself, doesn't mean much as there were probably different versions of the ecm depending on the exact configuration of the truck.
The part number he gave me is F6TF-12A650-AND (code GLU3), whereas the one sure ecm I can identify for a MAF 460 is F6TF-12A650-AMD (code FEZ3).
Can anybody tell me for sure if this ecm is an original 460 MAF unit? The dealer I talked to couldn't help me because this is too "old".
This unit is OBDII and EEC-V. Were the late non-California 460s (speed density) also switched over to OBDII?
Thanks!
This unit is ODBII and EEC-V. Were the late non-California 460s (speed density) also switched over to ODBII?
Thanks!
The guy that has the ecm wants a not-cheap price for it, so I have to know what this unit's application is before doing anything.
Also, it is my understanding that all vehicles sold in the US from '96 on where required to have OBDII. Were the trucks somehow exempt from this?
Thanks for any help.
So this may well be a mass-air 460 ecm. How the heck do I find any info on this thing? I can probably dig up a vehicle wiring diagram somewhere (Maybe. Any suggestions on this would be great too!) but info on this stuff is rare.
My '96 F-350 w/460 is Federal, and speed-density. I want to do the mass air conversion ultimately, but will play with the existing ecm for a while first, in order to learn a few things first. I know going to the 104 pin ecm connector and OBDII will be a major wiring job, but I've got all winter to plan it out. I believe that I can build pretty much the entire system on a table and run it as well. That would let me know that everything is good before trying to drop it on the truck's engine.
