Dizzy, plug wire combo
Old Sep 6, 2012 | 10:37 PM
birdhaus's Avatar
birdhaus
\\Also posted in engine build forum
Howdy, I'm replacing and upgrading a couple things in my '65 f-100.
The 352 has an Edelbrock intake, Holley 600... stock cam, one wire 120 amp alternator..
Its not running great, keeps fouling plugs and at idle develops an intermittent lope / miss ...
It also has a Pertronix D7133701 Flame-Thrower Vacuum Advance Electronic Distributor and Igniter III coil. I'm running accel superstock 7mm plug wires,
Fuel-system wise, I think we're ok, was wondering if these wires are up to the task?
I just pulled 3 out of 8 plugs fouled...
image of Distributor/wire combo: http://www.birdhausdesign.com/truck/Dizzy.jpg
Can't figure out how to post a picture in a new thread.
Thanks for any advice or detective work!!
Old Sep 7, 2012 | 06:12 PM
69cj's Avatar
69cj
More likely you have a fuel, Carb, problem or oil problem. Valve guides or rings. Have you taken a compression check and vacum reading while idling and at a steady 1500 rpm?
GoF700Go
Large Truck
Oct 21, 2012 12:55 AM
birdhaus
Sep 9, 2012 05:34 PM
Phity Five
Oct 27, 2005 02:36 AM
76 F250 4X4
31
Sep 14, 2004 12:57 AM
Like M. Fords
Dec 13, 2002 02:08 AM
