Dizzy - plug wire combination
Old Sep 6, 2012 | 07:20 PM
birdhaus's Avatar
birdhaus
Howdy, I'm replacing and upgrading a couple things in my '65 f-100.
The 352 has an Edelbrock intake, Holley 600... stock cam, one wire 120 amp alternator..
Its not running great, keeps fouling plugs and at idle develops an intermittent lope / miss ...
It also has a Pertronix D7133701 Flame-Thrower Vacuum Advance Electronic Distributor and Igniter III coil. I'm running accel superstock 7mm plug wires,
Fuel-system wise, I think we're ok, was wondering if these wires are up to the task?
I just pulled 3 out of 8 plugs fouled...
image of Distributor/wire combo: http://www.birdhausdesign.com/truck/Dizzy.jpg
Can't figure out how to post a picture in a new thread.
Thanks for any advice or detective work!!
Old Sep 7, 2012 | 05:26 AM
xlt4wd90's Avatar
xlt4wd90
Those wires should be fine. If you're uncertain, try idling the engine at night and look under the hood for any jumping sparks.
The other thing you can try is pulling one of the wires on the fouled plugs while idling and see if it changes.
Is it possible that the carburetor is not working properly? I had an engine that did what you described, and it was due to a leaking gasket between the power valve and the carburetor body. The combination was very similar; Holley 600 vacuum secondary on an Edelbrock F4B manifold on top of a 302.
Old Sep 7, 2012 | 04:40 PM
birdhaus's Avatar
birdhaus
Thanks for the hint on old sparky.. The carb has been the prime suspect all along, its brand new, but in the world of carbs, that means nothing. I'll try the power valve diagnoses tomorrow. A busted power valve is open all of the time, making the engine rich at idle and part throttle. The check for blown-out power valves is to the idle-mixture screws all of the way in. If the engine starts and idles without stalling, its leaking.
Old Sep 9, 2012 | 05:24 PM
78fordman's Avatar
78fordman
Which cylinders had bad plugs? You do have your vac advance on ported vac correct?
Old Sep 9, 2012 | 05:34 PM
birdhaus's Avatar
birdhaus
It was actually 1-3, and guess what?, brand new holly, leaking like an old bucket, it was drowning that whole side. A buddy of mine came by with the exact same carb, we strapped it on..
Smooth as silk. I'm not going to fix it, givin its 2 weeks old, I'll either send it back or have it replaced.
So yet again I was chasing my a**, so you guys were on the right trail while I was off on a snipe hunt.
Thanks....
birdhaus
Sep 7, 2012 06:12 PM
waterdawg69
Jun 9, 2012 01:29 PM
OldBlue68
Jul 24, 2008 12:08 PM
packrat56
Nov 17, 2004 12:36 PM
76 F250 4X4
31
Sep 14, 2004 12:57 AM
