moving map sensor port
Old Sep 6, 2012 | 02:30 PM
mikec91's Avatar
mikec91
What is the reason and were to
Old Sep 6, 2012 | 03:28 PM
fordpride's Avatar
fordpride
Do you have a intercooler ?
Old Sep 6, 2012 | 03:29 PM
mikec91's Avatar
mikec91
Yes and a chip
Old Sep 6, 2012 | 06:55 PM
fordpride's Avatar
fordpride
Move it to the hot side pipe. It will let you fuel a little more
Old Sep 6, 2012 | 06:59 PM
mjonesjr's Avatar
mjonesjr
Moving it to the hot side of an intercooler will fuel the truck a little more to compsenate for the boost that the turbo is putting out. It will also shift the transmission better if you have an auto.
The extra fuel added to the more dense air charge will allow for a shade bit more power and a more complete fuel burn.
Old Sep 6, 2012 | 10:34 PM
oldbird1965's Avatar
oldbird1965
Sorta like this.
Old Sep 6, 2012 | 10:35 PM
mjonesjr's Avatar
mjonesjr
Yes. I've got my boost sensor reading off the cold side.
Old Sep 7, 2012 | 02:05 AM
glovemeister's Avatar
glovemeister
Interesting I may have to try this. Any particular method to attach it? I'd assume just a nipple welded into the pipe?
Old Sep 7, 2012 | 05:42 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Or drill and tap for a barb fitting.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 7, 2012 | 08:59 AM
redman84's Avatar
redman84
What is different about having it in the hot pipe vs the factory location?
Old Sep 7, 2012 | 09:15 AM
mjonesjr's Avatar
mjonesjr
The factory location sees less boost, thus not adding the extra fuel. With an intercooler, you lose PSI because the air charge is more dense. If you move it to the hot side of the intercooler, your MAP sensor will fuel for the extra boost and also shift the transmission the way it should with the added fuel/more complete fuel burn.
Old Sep 7, 2012 | 10:43 AM
mikec91's Avatar
mikec91
Thanks for the info
Old Sep 7, 2012 | 11:34 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Less turbo lag too.
Old Sep 7, 2012 | 12:01 PM
redman84's Avatar
redman84
I see. I didn't realize it would make that much difference since the factory location is kind of the hot side as well. I think I understand moving it to the cold side a little more.
Old Sep 7, 2012 | 12:23 PM
mjonesjr's Avatar
mjonesjr
Once you install an intercooler, the factory location is on the cold side of the intercooler.
