I have a 1999 Ford Ranger, standard, 3.0 engine, front wheel drive..
It is weird but I did not know anti freeze leaked from here..I checked raditor, hoses and all is dry but it is leaking out, I refill with coolant every other day. I was wondering where in the heck the leak was..I removed a cover that is close to back of the hood of truck, i never thought anti freeze went there, when i removed the cover, i seen it leaking out..
Is this a hose been disconnected? this is recent, a few weeks.. Its looks like a black nozzel..
Could that be the "duck bill" valve that allows water to drain out of the a/c? Are you sure it is antifreeze and not just clear water?
The best test is to have your coolant system pressure tested to see exactly where the coolant is leaking. A pressure tester is like a hand pump that connects at the radiator cap and builds up 15-16 psi to simulate a running engine. If the pressure holds, there is no leak, if the pressure bleeds off there is a leak somewhere that you will be able to see somewhere under the hood.
Well if its on the ground, I guess I dont have to use that, it is leaking from somewhere.. It is dry from raditor cap, hoses all on top.. however, my resivior tank is always bone dry after i fill up the next day..
I filled the reservoir tank, radiator, took it for a spin, popped the hood, yes, i also been using the ac, hotter than hell here in Texas.. it is a mixture, I put a bowl underneath to catch what is leaking, I will take picture it..
Basically what I am seeing is water and coolant mixture.. it is green, slippery..what could this mean?
ok, thank you for the response. So is this why my reservoir tank get empty? what i see is anti-freeze when it leaks.
Is that why I see what looks like white fumes when running the ac because of the heater core?
