leaking coolant please help
Old Apr 14, 2007 | 04:08 PM
CHUCKK24A2's Avatar
CHUCKK24A2
my truck is a 1993 2wd automatic trans with a 300 it was leaking coolant and it seemed to to be leaking from the lower hose i changed it but know its leaking only when i turn the engine off i cant tell where its coming from but the water gathers and drips from the corner of the oil pan i hope that makes sence
Old Apr 14, 2007 | 05:57 PM
88 f150's Avatar
88 f150
Have your radiator pressure tested.
Old Apr 14, 2007 | 06:31 PM
t4kne's Avatar
t4kne
I had a radiator leak that sounds much like that. It leaked down the cooling fins and ended up gathering on the hose ,making it appear the hose is leaking. I took it to the shop and they did a pressure test and the pressure test looked ok. I found it by laying under the truck and watching with a bright light for about 20 minutes. It was a tiny hole that wasn't enough for a typical leak test to find apparently.
Old Apr 14, 2007 | 09:12 PM
spike552's Avatar
spike552
mine was the same way, replaced the fan thingy and lower hose, still leaked, i grabbed a small mirror and looked under the water outlet and i had blown the gasket, pretty retarted on mine ford only used 2 bolts and not one of em is on the buttom portion of the outlet.
water outlet where the thermastat is have fun good luck.
Old Apr 14, 2007 | 09:29 PM
alabamabuddog's Avatar
alabamabuddog
Sounds like your water pump is leaking to me. Theres a hole on the bottom of the water pump to indicate that the packing has failed. This leak sometimes will flow down the lower hose.
Old Apr 14, 2007 | 10:27 PM
Dryfire152's Avatar
Dryfire152
If you cant find a fluid leak, than use a dye and a black light. works good for oil leaks to.
Old Apr 14, 2007 | 10:38 PM
CHUCKK24A2's Avatar
CHUCKK24A2
cool ill check it tomorrow with a mirror and just realy look at it check the radiator and water pump thanks
